fantomfan57
Snagged this Model 88 this week. Mediocre packing, but it survived! Needed cleaning, really needed cleaning.
The bag basket smelled of....? So it needed to come out. Minor issue with removing the front door frame, but it came off. The basket went into a hot water soapy bucket to soak.
This allowed the removal of the top handle because.....the switch would not stay on. After some extensive investigation, I found out where that loose spring/clip needed to be to make the switch stay on and stay off.
After a good scrubbing, the bag basked was as good as new.
When I removed the basket, there was quite a bit of rust inside confined to the inside body. Wire brushing and a coating of Rest Reformer took care of that. Had to wait to do that because of the outside temperature.
Got it reassembles and it works. Motor sound good. Did a bit of cosmetic work for the scrapes and chips.
I will try to find a color match to spruce up the worn areas.
I already have the tools for this model.
Would love to have a copy of the User's Manual. I downloaded one, but the scan was not straight nor flat.
