I recently went through my Electrolux power nozzle wands with the sheaths and disassembled them. I'm glad I did so as several had become rusty and were not easily taken apart.
After I got them apart I took a dry soap pad (common brand name in the U. S. "S. O. S Pads--for "Save Our Saucepans") and went over the rusted areas--regular steel wool would do, too; I just used what I had available. Then I sprayed the inside of the wand section with the flared end to inhibit further rusting and to aid reassembly.
I am going to spray the wand locks with WD-40, too, as several are rusty; and I don't want them or the tabs to weaken and become corroded and eventually break.
I like the disassembly feature for making it compact for storage, transporting, posting, or for using the power nozzle to clean stairs and mattresses.
________
Wand/Sheath Styles and How to Disassemble & Reassemble:
1) circa 1969-70 (for PN-1): telescopic wand with ribbed teal sheath; wand lock button; (I'm unsure if disassembly is possible)
2) circa 1970-72 (for PN-1): smooth teal sheath with tight horizontal ribbing on front side and single wand; wand lock tab; cord is attached to sheath at bottom and hangs freely at top - to separate pull out from top; to reassemble do the opposite
3) circa 1972-74 (for PN-2): smooth teal sheath with tight horizontal ribbing on front side and 2 fitted wand sections; wand lock tab; cord is attached to sheath at bottom and hangs freely at top - to separate pull out from top; use finger or screw driver to bend back spring latch to separate wand sections; to reassemble push wand sections back together and ensure they are latched before slipping back into sheath from the top
4) circa 1974-77 (for PN-2): smooth ivory sheath with tight horizontal ribbing on front side and 2 fitted wand sections; wand lock tab; cord attached to sheath at top and bottom - to separate pull out from top by using finger or screw driver to release spring latch to separate wand sections; to reassemble push wand sections back together and ensure they are latched before slipping back into sheath from the top
5) circa 1977-82 (for PN-4): smooth ivory sheath with tight horizontal ribbing on front side and latch cut-out and 2 fitted wand sections; wand lock tab; cord attached to sheath at top and bottom - to separate pull out bottom section first after lifting wand section adjoining latch; pull out top section from the top after releasing top latch; to reassemble slip the top wand section back into sheath then push bottom section in making sure latch fits on tracks in cut-out until it snaps into the top wand
6) circa 1982-85 (for PN-4A): smooth ivory or light gray sheath with tight horizontal ribbing on front side and latch cut-out and 2 fitted wand sections; wand lock button; cord attached to sheath at top and bottom - to separate pull out bottom section first after lifting wand section adjoining latch; pull out top section from the top after pressing wand lock button; to reassemble slip the top wand section back into sheath then push bottom section in making sure latch fits on tracks in cut-out until it snaps into the top wand
Wand Section Traits (pairing different style sheaths and wands may cause wands to get stuck, latch to break, or sheath to crack)
PN-2: app. 1/4" width wand latch; upper section latch button hole is on back side (opposite wand lock tab)
PN-4: app. 1/2" width wand latch; upper section latch button hole is on front side (same as wand lock tab)
PN-4A: app. 1/2" width wand latch; upper section latch button hole is on front side (same as wand lock button)
Corrections/Additions welcome. Information on later wand/sheath combinations appreciated.
________
