Electrolux Model LX Question
electrolux137
Bronze Member
Los Angeles
I have a question about my Model LX -- something that's really stumping me.
After I got it back from the guy who polished the trim, I put it all back together.
When I turn it on, I can hear the hissing sound of suction escaping from around the bottom by where the ejection lever is.
I took the front cover off and looked around but didn't see anything amiss. There's a gasket around the hole in the bottom of the housing that aligns with a smaller hole inside the blue part of the cover that screws to the bottom of the housing.
Does anyone know what might be causing this? I will note that it's the oldest LX with no ejection control knob.
Thanks in advance.......
Electrolux Model LX gasket.
Hi Charles:
My guess is age, after all it would be 72 years old. I think the rubber has cracked, or simply worn out. Things like this are common for vacuums this old.
How loud is this whistle? Is it heard over the sound of the motor? As I recall, when the wrapper (bag) was almost full it would whistle indicating it was ready to eject.
Maybe you should check all rubber parts. As I say, this machine would be 72 years old.
Charles.
Go to Lux 30-XXX tools, reply 86 and 87 to see what I'm talking about. Gasket 5705-4 and the smaller one with plunger assembly. As you and I both know these machines like the back of our hands, should be easy to figure out.
Good Luck
Alex.
Well Alex, you have identified the problem with the photos you posted. See the photo I attached here and note the red circle. There's a rubber gasket in your machine and not in mine.  So I assume that's the problem, but the bigger problem is ... where one earth am I going to find one???
Thanks very much for your help!
Model LX now runs perfectly!
<div data-contents="true">
<div class="x1e56ztr" data-block="true" data-editor="6qgks" data-offset-key="87tos-0-0">
<div class="_1mf _1mj" data-offset-key="87tos-0-0"><span data-offset-key="87tos-0-0"><span data-text="true">Thanks to Marc </span></span><span data-offset-key="87tos-1-0"><span data-text="true">Turbyfill</span></span><span data-offset-key="87tos-2-0"><span data-text="true"> of Harold's Sewing & Vacuum in Spokane, Washington, my beautiful Model LX is now running perfectly. He sent me the missing rubber gasket inside the front cover and I installed it today. EUREKA! er ... ELECTROLUX! :)</span></span></div>
</div>
<div class="x1e56ztr" data-block="true" data-editor="6qgks" data-offset-key="73sh8-0-0">
<div class="_1mf _1mj" data-offset-key="73sh8-0-0"><span data-offset-key="73sh8-0-0"><span data-text="true">Here's a video...</span></span></div>
</div>
</div>
http://www.1377731.com/0000000/lux.lx.mp4
