electrolux1969
- Joined
- Aug 26, 2007
- Messages
- 14
Hey any of you guys had any luck fixing the bag system? While I was working on the motor I decided to look at the ejection system to see if I could get my working again.I pulled the front hose assembly off to find that the brass rivet inside where the hose goes in was all gummed up.That hole is so small anyway it wouldn't take alot to mess it up.All the vac hoses are still good.There was another brass hose connector that leads to the ejector control that was also gummed up.I ended up taking it all apart,cleaned all the rubber parts( the diaphram,o-rings and seals)blew out the hoses and cleaned the entire housing really good.Man all that dust and dirt in there!! It wasn't to hard to do neither. I was kinda scared about doing this because I heard some other people say it was a diffuclt job.I got it all back together.The whole job took about an hour.Of coursse I don't have a full bag to test it out right away,I just have to wait till the new bag gets full.I'l let you know if it works or not.Thanks,
Mike
Mike
