sweeperboy
I have an Electrolux LE (Marquise era) and the switch is broken. It has been abandoned for years in a basement as it wouldn't turn off and I finally took it apart and discovered the switch cover which you push is fine, but there is some type of lever or rocker that has broken. Can I order components or is is an entire assembly? Is it a difficult repair? I know reassembly can be a much different experience than disassembly. Thanks
