My dad received this vacuum for free from Amazon Vine. It's a cordless 2-in-1 stick and hand vacuum by Electrolux, colored in Satin White.
This is a very nice little vacuum to use around the house. It utilizes an 18V DC lithium-ion battery that claims up to 45 minutes of run time. Charging is done via a base that sits on the floor. The vacuum has a two-speed motor that can switch speeds (high and low) via a button on the handle.
The middle part detaches to become a Dustbuster-like hand vac for hard-to-reach areas. There is a 2-in-1 tool with a brush that can be pulled off to use as a crevice tool.
The stick portion features a swivel head and a bright LED headlight. The motorized floor nozzle features "Brushroll Clean" technology where I can step on a lever to remove long hair without having to cut it off manually. It works pretty well, but the vacuum sounds like a saw while the brushroll is being cleaned.
The vacuum was simple to assemble, and does a great job cleaning both carpets and hard floors. However, the dust cup is tiny, which is typical of stick and hand vacs. But it is simple to remove and empty.
Overall, this vacuum is much more convenient to use than my corded Eureka Flash stick vac. Here are some pics of it.
