hi guys,
my mom has an electrolux e2000 with the pn2000 power head (canadian).
The power head has been used maybe a handful of times so its been sitting for probably 20+ years..but we now need to put it to use.
There are no buttons or switches on the wand or the power head so im guessing it just powers on when you plug the head into the wand, but it's not working.
At first i thought maybe the motor wasnt working so i found a cheap one for sale nearby. I went over and tried his, same result, wasn't working..it must be an issue with my vacuum or hose.
So i grabbed a multimeter and poked the leads into the hose:
With the hose attached, and the vacuum plugged in (but not running) i get 0.54a
With the hose attached, and the vacuum plugged in (and running) i get 0.8a
*whether i took readings with the electric wand attached or not, the results were the same..so the wand seems fine.
i then tried removing the hose+wand and attached my leads directly to the small metal contacts in the vacuum itself:
with the vacuum plugged in (but not running) i get 0.73a
with the vacuum plugged in (and running) i get 1.9a
What do you guys think, something is broken in the hose?
When i took apart the power head i saw no fuses, no switches. I did get readings directly at the motor (i seem to remember them being quite high but i forget, ill have to check again).
Pls help. Thanks!
Pls help. Thanks!
