Electrolux Box Resto
detroitdirtbag
Bottom of the Bag
I’ve used the paper repair tape to mend or repair old boxes before, the cardboard on the old Electro attachments are so brittle, one tab has been broken off the sprayer box, luckily it was in the bottom of the box. You can buy the pre glued paper tape online, simply wet, and stick. I wet the cardboard a bit in the repair area, then put a weight on it to straighten it and keep it from warping when drying. I repaired an old Robot toy box from 1969, thought I’d try to preserve these boxes. Also you can add a pc to keep from breaking any further too. Your going to want to look at the PCs from time to time, it helps the old cardboard from any further breaking or cracking. Works good to reinforce corners too.
The
Tape you use is what quite a few companies use to ship heavy merchandise. It's the best packing tape I've ever seen or used.
Also if you have really messed up boxes, you can get some paste glue that you brush on and cardboard mailer inserts, glue those to the inside of the box and make a new liner. They come in various thickness, I've done it to preserve some boxes that started getting crushed to make them stronger.
I did this a while back thought I’d post it again, found this empty 18 pack of bags flattened out in a drawer, not sure what year, I cut a combo of pink foam and wood to get the thickness, not sure why I saved it, but my mom did all those years, so why not lol,,
I appreciate old art design and vacuum parts packages, I do the same when I use up a packet, I stick it in a file carrier and save it. Some have really neat designs and colors, especially for the early 70s and late 60s era.
