delaneymeegan
Those of us who love our metal Electrolux vacuum cleaners, have no other filtration except the bag. And a four ply bag is awsome.
One issue is, there is no pre-filter. There is also no exhaust filter. Even Kenmores and Hoovers have those.
So, sealing any possible void is essential. Yet, the typical Electrolux bag is supplied with a tab accross the opening. This tab should be removed before using the bag. This is also true of the Electrolux uprights, that have a similar, but longer bag.
As Electrolux137/Charles so kindly explained in another thread titled "The great HEPA debate", there was a design problem with the LX and LXI models, and a bag that was "self sealing" was necessary to keep from disaster:
"When you remove the bag from the machine, the tab closes off the little opening to keep dirt from getting out. This was particularly important with a (correctly functioning) LX or LXI. When the machine shut off and ejected the bag, the bag would sail -- at great speed -- across the room for 5-6 ft. When the bag landed on the floor, if the membrane wasn't sealed, dirt would "poof" out of the opening."
So, the long ago created LX and LXI are distant memories, and frankly were rather obnoxious, but every manufacturer has had its no so great designs. I still love my metal Electrolux canisters.
The tab serves no real benefit when used in any other Electrolux AND more importantly, when left in place, serves to allow dirt to leak into the vacuum chamber, and because there is no other filters in a metal canister, get spewed out of the machine.
I did a little experiment using my Ultralux Classic to illustrate why these leak when used with the tab.
How things typically proceed when inserting a vac bag in an Electrolux canister.
I'm using an off-brand bag and look what happened. The cardboard tab actually ripped the rubber. If I weren't aware of this issue, I may have just closed the door and been done with it. It will still work for this experiment.
