Electro Hygiene motor help
Kirbyclassiciii, sounds good to me. Thank you.👍 One thing, I found one on eBay and it's part number 1608001. It looks almost like mine. Will that work as well?
Gj9696
This armature (1-608001-000) will work with the existing field coil (1-801002-000), but only if you also use these following internal parts:
1-608261-000 driveshaft
1-608004-000 impeller fan (1/4" diameter shaft hole)
