williamnilliam
Hello everyone! So I've recently decided to dive into the world of (older) Dyson and just picked up this DC17 on FB marketplace for $30 USD. I believe this is a Total Clean model but I'm not entirely sure since the label is gone. I do know it is a later model (seller said around 2012 ish).
Everything seems to work however there is a noted lack of suction, so after doing some reading and watching some videos I decided the best course of action would be to take the cyclone apart and boy I'm glad I did. This thing was absolutely filthy and plugged up! Interestingly this model only has the single cyclone where as every one I've seen a video on has 2, which points to this being a later model.
The HEPA filter definitely needs to be changed but I'm not sure if the pre motor filter needs to be replaced or if a wash would be enough.
I've also noticed that the U pipe going up to the hose doesn't make a full seal with the upper pipe, I feel like it should be on there better.
So I'm going to throw the cyclone parts in the dishwasher (minus the painted top), do I run it with just water or what kind of cleaning agent should I use for this? I'm new to this but having a lot of fun learning.
