Dyson DC07 Animal Spa sessions
beko1987
Stokenchurch, United Kingdom
I made a start on this on Friday night with the Cyclone.
Tools ready (Not seen is Minder on TV)
From Dc07 Evan
Bin stripped
From Dc07 Evan
Cyclone top off
From Dc07 Evan
I cleaned this out 3ish years ago!
From Dc07 Evan
From Dc07 Evan
From Dc07 Evan
From Dc07 Evan
Bin flap latch dis-assembled
From Dc07 Evan
Little seal
From Dc07 Evan
It was all blasted off in the shower and left to dry for a few days (until tonight actually)
From Dc07 Evan
From Dc07 Evan
From Dc07 Evan
The contour earled it's keep throughout
From Dc07 Evan
It was still early, so I grabbed the rest of the machine.
Cable off
From Dc07 Evan
From Dc07 Evan
Polyfilla all over thebase plate
From Dc07 Evan
From Dc07 Evan
From Dc07 Evan
And that's as far as I got, as I'm waiting for my (hopefully) long enough torx driver to arrive
From Dc07 Evan
Pile of bits for washing
From Dc07 Evan
And waiting
Put the cyclone back together this evening. Need to clean that seal a bit more though
From Dc07 Evan
From Dc07 Evan
From Dc07 Evan
And that's it for now. Motor and clutch out next hopefully. Bought new belts too, so hopefully changing 2 clutched belts isn't too hard...
Awesome! I had a DC07 Animal last year and now there is one on Gumtree for 20 pounds, I will buy it hopefully, (most likely) and It is good to see a Dyson being refurbished properly :) PS how do you clean the eeals? Like they do get stained, and I use soapy hot water but unfortunatelyvtueycstill look stained :( Thanks, Tayyab
Tayyb - I use baby wipes! 1 to get most of the rubbish is off, then another one rubbed well to get the staining off. Can be very satisfying! I don't clean them in the shower for fear of them going down the plughole
Thanks Sam! And yep I agree with you about washing the seals in the sink, so Hows the DC07 refurbishment so far? I might get my new Dyson (either a DC25 All Floors, a DC07 Animal or a white DC14 All Floors) and post pics of cleaning it out too :)
Well, half of it is spread out across the floor dry, the rest is yet to be started, however I received a longer t15 torx driver, a belt removal tool, some new belts, filters and the unofficial service manual (which is fairly good).
My plan tonight is get home early and get the rest apart for washing, get it drying and get the belts changed. The cyclone is back together now, everything else will go in a box until it is ready to go back together! I showed the intended recipient pictures of it so far and he was impressed and pleased too!
Amy came home with a DC04 that belonged to one of her friends, which was dead. 10 minutes and a few inches of cable chopped off later and good as new! I washed the filters out for her friend, she can take it back tonight. Might start charging if enough people ask me to repair them, make some beer money!
Lol wow! Thats cool, I was about to repair a family friends dc27 as the brush didnt turn, the clutch was just probably off :P
Just a quick question- would you prefer a DC07 Animal or aDC14 All Floors with a white cleaner head and cyclone etc
Regards
Thanks :D I like the DC14 wand better but I hate the awful large debris channel as there is not full suction in the carpet, with my allergy one I blocked it up and it worked much better
I used my air compressor to blow out the cyclones in my DC07 and it worked great! Also replaced the Post motor filter or HEPA filter under the bin. It works like new again!
The conclusion of this saga!
My new longer t15 security driver came on Monday, so I wasted no time in finishing the stripdown
From Dc07 Evan
From Dc07 Evan
From Dc07 Evan
And finally out!
From Dc07 Evan
5 years old
From Dc07 Evan
New belts ready
From Dc07 Evan
Old motor-clutch belt was very stretched
From Dc07 Evan
As was the clutch-brushroll one
From Dc07 Evan
Oiled the bearings
Clutch back together, I carried on the stripdown
From Dc07 Evan
From Dc07 Evan
From Dc07 Evan
From Dc07 Evan
And the final load of washing
Second pile of seals
From Dc07 Evan
From Dc07 Evan
And so to tonight. Everything was dry and bought out
From Dc07 Evan
Why do dysons shed so much carbon dust? Quick wipe with cif later
From Dc07 Evan
From Dc07 Evan
Once I'd realised to lip the seal over the motor it went in fine!
From Dc07 Evan
The next stage was full of frustration as I'd forgotten the order it goes in, so took it apart more than once, still, random pictures
From Dc07 Evan
From Dc07 Evan
From Dc07 Evan
New post motor filter. The seals had no sticky on them so I superglued them to the filter housing
From Dc07 Evan
freshly belted clutch back in
From Dc07 Evan
Oiled and cleaned brushroll
From Dc07 Evan
Definatley needed the belt tool, the new one was soooooo short compared to the old one. Got there in the end though
From Dc07 Evan
And done!
From Dc07 Evan
From Dc07 Evan
From Dc07 Evan
From Dc07 Evan
From Dc07 Evan
From Dc07 Evan
I then vacuumed the entire flat with it, and it's so much better. Was a pleasure to use, and picked up alot, but the howling noise it makes now the cyclones are clean would drive me nuts! I'm 99% sure I haven't left a seal out, and the noise stops when the cyclone is removed.
Still, sure it will block up and go away soon!
Before
After
Now all that needs to happen is my friends offer get accepted on this house, then it can have a new home!
WOW it looks so brand new! have you replaced the brushbar? that would be amazing when it comes to grooming the carpet, for a clutched Dyson it would make quite a difference, and Well done on cleaning it up! not even a speck of dust on the machine
One of the best refurbishments I have ever seen
I thoughts they were excellent for thin pile, but when I used my clutched DC14 Allergy on my thick wool Rug, it was terrible at grooming, so I used the DC25 Animal, which was way better
Ok, I personally recommend the DC15 as it got an amazing brushbar that grooms like a dream and has great suction, but a better alternative is the DC25, less suction but stillcstiff brisyles and is like a simplified DC15
But the Helix is a crappy brush because of 2 rows of bristles
