Does Rainbow E2 Black really need a hepa filter?
vintage_kitchen
Central Kentucky
Hey everyone, I was a member in the past, but life took me a different direction, and while I no longer collect, I have missed the site, and I have a question I know only you guys can answer.
I searched the forums, and could find no real consensus on this, does the Rainbow E2 Black really need a hepa filter? I've noticed on my year old Rainbow, it seems to have better airflow with the filter removed, even after rinsing it. Growing up we had a Rainbow D4 SE, and it seemed to have amazing filtration with just water, better than grandma's Kirby Tradition, and at least equal to my aunt's Filter Queen Majestic (maybe a little better, it made the air smell so clean).
So does my E2 really need a hepa filter to be effective at filtering the air, or is it just a gimmick and better removed to improve airflow?
If it really does need the hepa filter, maybe mine needs replaced? Or is it just the nature of dense hepa filter material to somewhat reduce airflow?
It does indeed need a hepa, the hepa does 2 things for the 2 speed units, one it captures the particles that bypass the separator and yes that does happen as not all dirt is water soluble, and 2 it gives the machine some back pressure... these machines actually have quite a bit of airflow and waterlift. As a matter of fact without the hepa filter In place the machine will start to disperse water out the back of the unit.
Hopefully this answers your questions and it’s good to see you back!
I’m rereading your post too, hence the edit, but you should never rinse a hepa filter regardless of whether or not states it can be rinsed. That would definitely explain the lack of airflow. Definitely replace it and you will notice a world of difference!
[this post was last edited: 1/27/2020-22:50]
Rinse
The e series 2 speed gold, silver and platinum HEPA filters are the same.
You clean the filter. It's a heavy duty filter that's made to be cleaned.
Rexair tells you to rinse it. They made the machine you need to follow the instructions to have best performance.
There is a few Rexair dealers who can answer on this board. You can also call authorized service center. I think they know.
Yeah
Not a big fan of Rainbow. It takes very little dirt to make clean water look dirty. The older Rainbows had only 50 inches of waterlift or lower and I don’t like dragging around a pan full of water with me. Also I agree water is not a good filter medium.
I do pull my SE out every once in awhile. I do like using the fragrances with them and it is kind of fun to watch the water swirl around. You can mop with them which is nice!
It’s my understanding. That HEPA filters were added to get more certifications for Rexair AS purifiers AND to get around the ( justly so)criticisms about not capturing ALL materials( older ones couldn’t capture no water soluble substances ( ash, drywall dust, talcum power etc). I’ve never heard of the newer ones needling back pressure ( not outright disputing it though). I would feel quite comfortable using my e2 black w/o a filter and have at times IF I’m changing the water often and not trying to p/u non water soluble materials.
I've asked this before
because in 2006 when I bought my rainbow new, I used it for 5 years before changing the HEPA filter. And I didn't notice over that time if I was losing airflow. It felt the same to me, air always pouring out the back and good airflow. If you live in a house where people use baby powder, or flour gets on the floor in the kitchen or any type of super fine powerdery substances, you might as well plan on changing rainbow HEPA's frequently....but if you're just vacuuming up regular dust/dirt/food crumbs, pet hair, etc, no dust should skip the water and go onto the HEPA. You can get generic HEPA's for around 13 or 14 dollars. My last filter I replaced was generic and it's worked perfectly fine over the years.
Kevin, I Performed Some Tests A While Back
And hopefully, these videos will answer your original questions about Rainbow filters.
Reconditioning A Smelly Moldy Rainbow HEPA Exhaust Filter
Rainbow E2 HEPA Filter Tests Old Versus New
Closed Room Air Cleaner Test Using A Rainbow E2 Platinum
Bill
To clarify it's generally a bad idea to rinse a HEPA filter.
They're fine enough that you'll end up getting the impurities from the water in them. The parts and expensive enough to replace just replace it.
@vaclab you made an incredible amount of video on a $30 Filter.
Vacuum devil
How did you come to that conclusion ? From what I watched, despite several people's antidotal evidence(opinion) the washing of a hepa filter is doable .....i.e. can be done w/o sacrificing airflow or increasing air emissions. I"m glad he did all that testing to address questions of many vac collectors, to give credence one way or another to whether washing them can be helpful.
@rivstg1 #419222 #419307 I talked about it in the post above on video .
The HEPA filters are inexpensive enough they should be changed.
Not only is there a time cost benefit analysis to this.
But my 16 years as a vacuum technician ,I can tell you washing HEPA filters does not do them any good in the end.
As stated before will not acknowledge anything from vaclabs. Nothing personal.
I hope that answers your question of how I came to my conclusions.I believe you have disagreed with me enough on here to know who I am. If not allow me to reintroduce myself with the link below.
Have a great weekend!
https://www.youtube.com/user/ghostofchicken/about?disable_polymer=1
Mike
I knew one of the Electrolux usrsnames was yours. Either you post in contemporary forum or you don't post much. There's a few Electrolux usernames threw me off. I also thought you were a couple years older.
Hepa Filter
I can tell you from experience when I owned an E1 series that when I had removed the hepa filter to actually try to answer this myself, There was dust leaving the machine and I'm not sure why. I am an experienced Rainbow user so I know WHEN you need to change the water while using the Rainbow. I had a lot of concern from that moment on that Rainbow's do not filter as well as they claim. I eventually bought a new filter and installed it, then sold my last Rainbow. I currently use vacuums that have a fool proof bag change indicator to help me with determining air flow.
No you don't NEED a HEPA filter but I do recommend using one. Water does work pretty good at filtering. If not the HEPA would clog almost instantly.
I do not understand why the vacuum needs back pressure. Its not a car.... It also will not suck up water past the separator if its working properly. I have make a hepa filter frame that I use when I need Ultimate airflow and I want to preserve my usual HEPA.
If price is an issue then just order the filter through rainvac. They are awesome and its worth it, order you a HEPA filter and a few belts and some fragrances.
Update
I need to update my opinion on this subject. I currently am using a D3C quite often because I don't have much carpet at the moment. I always use a 4 quart water basin which I would always recommend when cleaning with a Rainbow. The additional water provides better filtration. I think the newer E series Rainbows have a lot more power and should definitely have a hepa filter installed and changed out once a year. Just my opinion.
Personally, I'd rather have a filter in any Rainbow E series. But if I'm worried about losing performance but still want to have the best filtration on any water vacuum, I'd get a central vac instead. Aqua-Air, CycloVac, DrainVac, or Kenmore, it doesn't matter to me.
Im about to open up a can of worms here but anyone that knows about home construction or energy efficiency will know this stuff.
1.. NO vacuum needs a hepa filter. Unless you have asthma and vacuuming actually affects you of others in the same room then you don't need a hepa filter. Even then the HEPA is WAY overkill for filtering.
2. What are you trying to achieve by using a HEPA filter on a vacuum? You aren't going to be getting any benefits from using a HEPA while vacuuming once you the machine is off. Your air infiltration rate and living location will determine how dirty your air is in your home.
If you are trying to filter your air in your home then you need to upgrade the filtration of you HVAC system. By that I mean getting a static pressure test done and determining what filter you need/want. There is some math involved but you want to keep you total system static under 0.5" w.c. with filter. To do that you will need to enlarge the filter area or add another filter box. I have never ran across a house that had large enough filters to keep a system running efficiently.
If thats not possible then build a Comparetto Cube or buy HEPA Air purifiers that are the largest you can get... but doing the machines adequately will likely cost as much or more then resizing your HVAC filters.
Another solution is which we all should be doing is air sealing our homes. At least that way we can control where our fresh air comes from in our homes and then filter it.
Lastly and most important is that HEPA does nothing for VOCs and CO levels. You need to get that air out of your home and bring in fresh, clean air. A vacuum should only ever be used to remove dirt from the floors and surfaces, NOT to clean the air you breath.
Shae,
I agree. I think hepa filters are not necessary for the reasons that you stated. Unless the operator and/or persons in the room have a medical condition or respiratory issues as you also stated.
I can understand why this topic comes up so frequently on this site since it is a vacuum cleaner forum. If a reader on here is obsessing over a little dust in the air please ask yourself the following questions: 1. Do I maintain a healthy weight for my body type? 2. I’m I eating a healthy diet. 3. I’m I making good lifestyle choices? Such as not smoking and getting the recommended amount of exercise? To me the items that I listed are more important than having a hepa filter on a vacuum cleaner.
Back to the original topic. Not trying to bash. I do own three Rainbows and use them from time to time for fun but as I referred to in my previous post I think Rainbow is one of the worst offenders when it comes to emissions. Depending on what you are vacuuming the hepa filter can become clogged on a Rainbow. Every E series that I’ve owned has come to me with a very clogged hepa filter. In summary, yes I think a Rainbow vacuum cleaner or any other water based vac needs some sort of additional filter to catch what escapes the water. Because depending on what you are vacuuming it can be a lot.
I'm trying to remember but since 2006....I've only gone through 2 HEPA filters on my rainbow and I'm now on my third. I've never used it without a hepa filter. I will say one thing I do... I fill the basin with more water...over the line..Not so much water than it causes issues...but more water than is recommended. Like 1/2 inch over the dome and line. I cringe when I see rainbow videos on youtube and I can tell there's not enough water in the basin..
anywayz - My house isn't super dirty because I'm a clean freak...but I've vacuumed up some nasty stuff with my rainbow..for a while I was using my rainbow to suck the bin of a bagless vacuum clean...you really can't get much more nasty than that..Afterwards, I would clean the separator and check the filter and it was fine...I've never experienced a rainbow filter clogging personally...the only reason I changed the two so far is because I just felt like it had been so long...
Yes - opening your windows and fresh air is best unless you're somewhere dusty. I had nice fresh air pouring through my house the all day yesterday.
I must take some issues with the comments above which claim that HEPA vacuums are "overkill" or don't do much to clean air. I don't mean to sound like a know-it-all. That's not my intention. However, there are many studies that show that HEPA vacuums (properly sealed) do in fact improve air quality in the home.
The act of vacuuming itself stirs up "latent" dirt trapped in the fibers of carpet or rugs. If a vacuum is poorly constructed or has poor filtration, more of this becomes airborne. A powerful vacuum will pull in and trap much of this before it becomes airborne. Poor performing vacuums will slowly gather dust in the bag, in the seals, in the hoses, etc. and often expel more dirt than they are picking up.
Good quality, sealed vacuums DO in fact improve the air quality after vacuuming. Some for several hours afterward.
Laboratory testing confirms what I have written. Labs with hermetically sealed rooms and spectrometers and other equipment can measure dirt before, during, and after vacuums are operated and have measured this data. I'm a person that likes scientific rigor and need evidence to support claims.
But I will say this. HEPA's make it easier for a vacuum to reach this status, but it isn't the ONLY way. Proper sealed construction is more important. While one can say that HEPA filters are not necessary, they do help and in my opinion are worth it.
@kloveland. from my experience with Rainbows, the clogging of the filters are mostly from people not changing them over time...and vacuuming up stuff that it wasn't designed to...but more than that last point, I noticed NOT changing the water often enough contributes to the dirt/dust NOT being submerged into the water ( due to already being saturated with dirt) and THAT new dirt going straight into the filter. I"ve only changed 2 filters in 12 years on my rainbows from , what I feel , is proper water management.
Lab tests are not home tests. Sure you and sit different vacs in different chambers and get different results... I'm telling you right now that you air in your home is changing every minute. If your air quality in your home is bad enough that a vacuum cleaner is improving it the you have some serious issues. Get a blower door test done and then come talk to me.
electromatik, please give us the links
that prove air quality is improved in a typical home. I would LOVE to see that.
Actually owning a newer type particle meter shows a very different picture of vacuum filtration. Here are some general numbers to consider:
1) Assume a small sealed bedroom with minimal furniture (no air in or out) = 1000 cubic feet.
Let's say the filter exhaust is 100 CFM (which is a lot), it would take at least 10 minutes to cycle the air through the vacuum, although room vacuum time would be around 3 minutes (carpet).
OK, great so the air is now cleaner. Now open the bedroom door and what happens? Your "dirty" home air instantly rushes in. So a sealed room isn't practical.
2) Assume an open door and a central HVAC system. The air is fairly clean already (hopefully) and the overall room (or floor) air volume is 10,000 cubic feet. Even cleaning at 100 CFM, the overall air quality improvement is negligible, although I've measured a short term improvement.
3) Assume an old, leaky house with poor insulation and no HVAC at all. Generally speaking poor indoor air quality. Any vacuum with high filtration would have such a small, temporary improvement in air quality it would be difficult to measure at all.
To see more about closed/open room particle tests, check out my playlist:
Bill
Well...
One thing I can say for sure (at least my experience)...when it comes to dusting the house...I have my hepa bagged vac..(which I love, btw) and my rainbow. I'm a clean freak but when I clean I don't do the entire house at once time..Since I do everything so thoroughly..... I'll do one room at a time..getting high and low and everything in between...over the years..I'll sometimes use my Rainbow while other times use my HEPA bagged... Now..there's not a hint of dust in the bag chamber...even going months without changing the bag... I can say for 100% certainty that I have to dust the house again SOONER if I used the HEPA bagged vs the Rainbow...I'm not sure why...the science says this shouldn't be the case...but it is just something I've noticed.. LOL...but that doesn't stop me from using my HEPA bagged more often because I have to be in certain mood to drag my rainbow out.
Dusting Sooner With HEPA
This isn't a surprise if you understand the difference between what a Rainbow expels versus what a HEPA bagged machine expels.
Consider the HEPA filtered exhaust. It's clean, dry air that will disturb your existing air. In short, it blows existing dust around without adding to it.
Older Rainbows (D4C) blasted your existing air with an unfiltered water mist, hence the "water washed smell". So, if mist is blown everywhere the tiny water particles will attach themselves to existing dust particles and drop them to the floor. Fabrics will absorb some as well.
Newer HEPA Rainbows have less "water washed smell" because the exhaust is obviously filtered now.
Bill
A typical install with central air "should" move around 400 cfm per ton. So if you have a 2 ton system it "should" move around 800 cfm. Now the numbers are probably much lower then that due to how most ductwork us undersized and most central air units are oversized. (bad old school practices and sloppy installs)
In Arizona you might be pushing 500 cfm per ton and in florida it might be closer to 300 cfm per ton for dehumidification purposes but still... that is WAY higher then a vacuum. And your AC should be running non stop all day when its at or above whatever you design temp is. If you filtering through a 4" merv 11 filter then great but make sure you are actually filtering that. Duct leakage is typically high.
NO vacuum will ever clean your air.. it barely is able to clean its own air.
I dont agree with the statement that older rainbows blew out mist but Id like to see that. I bet that came about from people who didnt know how to use it. I am impressed with the rainbow cleaning vs other machines. It does great at picking up fine particles like sand which is what I want. I dont care about filtration. If I did I wouldnt be living in a house. Even in my home with a window about 1" cracked all the time the CO2 levels are approaching 2000ppm. Recommended is 1000ppm, best is 800ppm, outside is under 400ppm. Measuring CO2 buildup is the best way to assume other pollutants are also high in the home. If you want clean air then get an ERV!
Dust is my biggest enemy..that and spider webs...I'm pretty good at controlling it if I keep up with vacuuming...But you can't have clutter or trying to dust everything is pointless and makes trying to control it much more difficult. Once you control your clutter it's pretty easy to vacuum everything...I'm not sure what the air quality is minus the dust...but dust is what I aim to remove...I already know the air quality probably isn't great in any home...regardless how clean...but dust annoys the hell outta me...when the sun shines in the room and I don't see dust flying all over or on flat surfaces.. I'm happy...
I still fill my house with eucalyptus while I'm using my rainbow. I swear I can smell it for days after cleaning..
I will ad this small thing: someone I live with uses a CPAP machine to sleep... they took it to the doctor after years to have the machine checked out... the doctor said....are you even using this?? this is the cleanest one anyone has ever brought me to check.. LOL LOL.. I love hearing things like that.
Hey Mark!. We have had this talk years ago , but for some reason when I use the Rainbow ONLY, I can see the difference in any dust that appears on the dark wood furniture. I don't know if the Rainbow filters better but I do know I have less dust and no odor when using the machine. I can't make that claim with other vacuums. Thinking about sending mine to be cleaned and new hepa filter as I have had it 12 years and it has seen a LOT of use. I got an estimate from the Rainbow dealer. I do take care of the machine and clean the separator often. I remember one time going to a vac store and they were showing an expensive German made cleaner. Even with the demonstration at the store, I could smell that stale, dusty odor when the machine was turned on. Sure no expert here and not claiming my Rainbow to be better than others but in my house there is a difference when I use it exclusively. Not sure I like the new model with the smaller water basin and the changes in the power nozzle.
