moderneezer
Even if the vacuum cleaners from Tacony (Riccar, Simplicity, Fuller brush, CleanMax, Maytag and Carpetpro) are good, there's something that worries me and it has to do with the compatibility of accessories with the different kinds of models. It's like, there are attachments for the Prima/Wonder canisters, others for other kinds of canisters, others for the clean air R20/S20 models, others for the older clean air models, others for the tandem air models and others (the 1 1/4" kinds to be precise) for the extension hoses that are to be connected to the uprights. I find that it's unnecessary that if we own a Symmetry or a Vibrance, we would have to use, for an example, a crevice tool for the onboard hose and a different one for the extension hose.
Sebo has simplified things by making it so that we can use the same non-electric friction fit attachments on all models, whether that model's a Felix or a part of the X series, G series, K series, D series, C series, Mechanical 300/350 series or Comfort 370/470 series, and we don't need another set of tools if we use the extension hose.
So my idea, for Tacony, is that they should make only one kind of compact turbine brush and introduce several different adapters for different kinds of vacuum models so that the same mini-turbo head and other accessories would be able to fit with all the different models of Riccar and Simplicity (and other brands related to Tacony) and so that the Floor IT and the Doom For Your Broom nozzles could be used with the uprights. And all of the future models of Riccar and Simplicity should be having hoses with the same diameter.
