sebo_fan
How is the weight of a power head even comparable to the wei
From what I can gather, although power head added canisters appears to be lighter from their smaller footprint, it is the ratio in which the weight of the vacuum is determined by the actual power head and tubes rather than using a canister for above the floor cleaning.
The Sebo floor head in question that I use, is the ET-H - That weighs 2kg on its own. Now, if you were to buy comparative bags of sugar - try tying that onto a pole and see how easy it is to shift around! It ain't easy but the SEBO head is easier to float because of its wheels underneath. I totally understand that not all power heads are heavy - but the SEBO's mechanism with the cord built into the exclusive metal telescopic tubing compared to their cord-without-tubes is also heavier. You then have the extra heavy weight of the 1.8 hose which also has an embedded cord built into it compared to the hose without on lower priced models.
With floor head added, plus the tubes you're looking at an overall weight factor with the Sebo K3 Premium totalling 8kg - about the standard weight of an upright vacuum. Go beyond that and yes, the canister idea is probably still going to be even lighter than average upright vacuums - not necessarily Kirby which I think is a bit extreme to compare.
Henry Hound models that use their power heads also have a heavier suction tube and bulkier hose, because an electric element runs through it. Whilst the procedure is seamless for cleaning, the use of the hose independently is bulkier and heavier.
You ask how I clean stairs? See the promo pic of Sebo X upright - I do similar and I also have an extra hose available, so even if I have to go further, the upright can either be lifted to one more step or tag another hose on. You could well argue and say that the extra hoses can't be stored on the machine like ones you get with the canister - but then again, not many canisters allow you to put on any other cleaning accessory other than the default small suction only cleaning tools.
