crazy Kenmore canister setup with long hose.
blknblu
CT
I had an old Sears central vac hose in great shape, and many Kenmore canisters with bad hoses.
So, I came up with this ..
It works well on the stairs.
I could easily add a central vac power nozzle, but this is fine for its needs. :)
Adding a power switch would be easy.
Have done the stairs, and the van.
This particular hose is long, lightweight, and flexible. The end is smaller than 1-1/4.
Almost threw it out a while back.
Never really thought about why the Kenmore hoses are expensive, until I realized it has three wires in it, instead of two (like a central vac). The power switch is on the handle.
this particular central vac hose has removable pigtails, so it is very easy to adapt to other systems.
I can hardwire a pigtail to the Kenmore end that plugs into the vacuum, and run it to the hose.
Right now, to turn the vacuum on, I just plug the adapter into the vacuum, and it starts up.
Great idea!
Looks like it would be awesome for cleaning out the car as well. I use a Riccar tool kit, which includes a 12' hose, with my machines frequently. It's great to be able to leave the machine in one spot, and clean all-around a room. The Dyson has a long stretch hose on-board, so I've used this setup for cleaning out garages, basements, and larger jobs where a whole lot of reach is ideal.
done the same thing!
I stuck an old rainbow hose on my Kirby legend and I put two hoses on it I use it to vacuum our basement and stairs
