Considering retrofitting Electrolux afterfilters to old canisters, and have questions...
minivanmegafun
Hi all,
I'm feeling ambitious and considering constructing something to retrofit the afterfilter that goes on later C-style bag Electroluxes (the High-Tech 2100/Diplomat and on) to older canisters (the ones with the upward-facing exhaust ports, the 1205 through the Marquise).
First, does anyone have any experience with this? Other than the accessory clip being in the way, it looks that this may not be too difficult to accomplish.
Second, what's this hole in the bag chamber for (this is in a Diamond J)? I noticed when disassembling that it's connected to the cord winder - I presume it's just a way to prevent over-loading the motor in the event that the bag clogs up and the cleaner doesn't shut off properly? I seem to recall seeing a thread about it a while back. What would be the consequence of blocking it off?
Thanks guys!
I tried that experiment once many years ago, retrofitting an after-filter on one of my machines. I used a spare hose-to-machine coupler; slipping the after filter on it them plugging into the exhaust port. There were a couple problems which became apparent. The hose coupler doesn't seal air-tight into the opening, and the motor chamber itself is not completely sealed, so some air was escaping through the cordwinder and the seams in the outer shell of the vacuum.
I have often wondered why Electrolux quit using exhaust filters at one point, and then years later started using them again. Even if they didn't perform up to HEPA standards at least they served to trap the carbon dust blowing off the motor brushes.
