Compact C9
Deleted member 1090
Hello every one i own a Compact Electra C9 and i bought a new exhaust filter braket or mounting plate if you will how do i go about remooving the old screws holding the braket ? This is the first time i tackle this project link below to indicatethe part im working on .Im talking about the exhaust filter ring that holds the black round exhaust filter how do i install a new one as the breaket has broken off leaving behind the metal rivets or screws .
http://www.ebay.com/itm/TriStar-Vac...919?pt=LH_DefaultDomain_0&hash=item25815feb17
any one ?
I am replacing the exhaust cap ring that holds the black round exhasut filter on the outside on my C9 electra i have to remoove the screws or metal revits and how do i d o it whit out damaging the maching thansk in advance .
Compact 9 rear filter removal
Compact9guy!
I recently did the same with my compact. Seems that the orignal ring is frequently broken from bumping or mis-handling. I found this out after talking with Tri-stars office. The gave me instructions on removal and replacement. It is very easy. I used the appropriate sized drill bit and drilled out the rivets. Careful to vacuum out the metal shards before going any further, I then mounted the new ring and used a "pop-rivet" gun to attach it. If you are un-familiar with the tool, any hardware or auto store will have one with an assortment of rivets. Just find the right size rivet and give the gun a good squeeze and you are done! These tools are pretty cheap and I have never run out of the rivets that came with the original purchase. Good luck!
http://www.ebay.com/itm/2-Way-Blind...un-Hand-Riveter-Set-Repair-Tool-/170902288072
Packardmanken Thank a bunch!!
Il do just that when i get my pay ill fix up my C9 Compact vacuum .
I rebuild the power brush got the original metal floor tool the rear filter is the last thing i needto do and it will be complete!!
I wanted a compact for so long now
