COMPACT C9 HELP!!!!!!!!
thevacomaticiec
Bronze Member
Bathurst New Brunswick Canada
help!!!
my lovely compact c9 is arcking in the blower port blue alot what is wrong with her ???? help help help she is arking blue i can see it in blower port almost no suction help !?!? is it the carbon brush ??? Or am i better off replacing the whole motor ???
Hi Antoine, That motor that you selected is not the motor that is in your C-9, starting with the C-8 they used a hi performance motor. Your motor is repairable, have you ever taken a Compact apart? If you send me the motor I will repair it for you no charge. It might cost to much to ship the whole vacuum to me, you can if you want.
Yes. That link you shared IS the correct replacement motor for your machine. When you replace the old motor with the new one, the machine will be "new" as the motor is the heart of a vacuum cleaner. It's a good price for the replacement motor on eBay. Very good price.
Carbon brushes
Iirc correctly acting is usually the carbon brushes wore out scraping on metal.
Here's a simple way to remember one speed canister vacuum wiring.
There are two leads from motor. Two from cord. Two from switch. Two from power nozzle receptacle.
Connect in this order:
One cord to One motor and One receptacle
One cord to one switch
One motor to one receptacle to one switch
In the end, there should be three wire nuts holding the eight leads in the above connections.
was wried acording to this NEED ADVICE NOW HELP i spent 100$ here
Can some one please message me ASAP i am literally about to cry here thsi is my lovely prize C9 put new motor in h ad plastic melt smell and fire alarm went off son of blank ..... i message the selelr for refund can some one please help me ty .[this post was last edited: 7/20/2021-12:25]
Dude
Swap the carbon brushes for old motor. There's no way there's 5000 hours on it.
I'd say try it the motors last forever.
