Cleaning a constellation...
schaicho24
Spokane
I have a Hoover constellation 843 that is in pretty darned good shape, but I want to clean the rubber ring, attachments, hose and cord. Also wanting to get small scratches off the paint. Any suggestions?
Also, where should I look for attachments? It is missing the crevice tool and the upholstery tool. Also I want the deluxe floor tool
I'd wash the attachments in warm soapy water, scrub with a sponge. If any marks are stubborn, use a magic eraser pad on them.
For the rubber ring you can use a magic eraser as well and then wipe with cleaner. If it needs it, the ring is fairly easy to remove from the top dome, I think it just pops out, but it's been awhile since I had mine apart.
Cords I usually just wash in soapy water too to loosen the grime. Just don't submerge the plug because it can let water in and cause corrosion. I take a towel or sponge and go up and down the cord to scrub it once it's soaked for a while.
Obviously don't plug it in until it's had lots of time to dry.
Car care products are good for cleaning the paint. I usually use a polishing compound to remove scuffs and light scratches. Then use a good wax to shine and polish it.
Attachments can be hard to find. You could try posting in the Super Market section.
Thanks so much for the information I just really didn't want to ruin it by using something won't. And the color attachment I need are a darker beige or light brown? I'll post pics soon :)
Soaking rubber and plastic in a bath of warm water and a dissolved dish washing tablet will work any grime and paint scuffs right out. I learned this trick from one of AlexHoovers94's posts on this site and have been using it ever since.
