Clean Obsessed "Electrolux"
dysonman1
the county
I have been having great good luck selling the Clean Obsessed tank type vacuum. This particular version is black and silver. With a power nozzle that features a serpentine belt for silent operation. The HEPA bags are awesome and I love the extremely high quality attachments.
Does anyone else sell or own one? I know it's available as the Perfect but the Clean Obsessed is so sharp looking and has all the 'extras'.
Very nice! Like the telescoping wand to use with attachments. Is there an extra shorter crevice tool included? Looks like one is on the machine in the first picture. I like how they still use the Electrolux combo dusting/upholstery tool too.
I would like an LED strip headlight for the power nozzle though.
It's a pretty solid built machine.
Doesn't really hold up to a lot of the other machines in its price point. Particularly maneuverability it lacks a swivel neck and modern casters.
I'm usually too cheap to buy things brand new, but if I had to pay retail for a new canister I'd probably go with this. I loved loved my Electrolux Silverado but old age finally got to it and parts kept breaking. Miele parts are way too expensive for someone that has to change bags often. This looks like a great way to get a new Electrolux without an insane Aerus price tag.
clean obsessed vacuum
I think this is similar to the Perfect C103 that I have and if so, yes, it's a great machine. I can't really see colors so that doesn't matter in my case. Even though it's a plastic canister, it uses the same hose as the metal Electrolux cleaners such as the 1205 and Super J. The hose does have one design flaw unless they have fixed it, the suction relief switch is very loose and will not stay closed, it slides open reducing your suction at the hose end, I put some tape on mine since I never use it.
I think the price of this machine is very close to the Aerus classic.
The electrical connector is standard on the hose so if you really want a power head with a headlight, you could use a power head such as the Wessel-Werk EBK360 which has an LED headlight.
Mike
I’d just get a used Aerus Lux classic that’s in good shape. And if these are priced similar to a new Aerus Lux Classic, is rather have the original than a Knock off which will likely break sooner and who knows if parts will be available. With Aerus, at least they are fixable for many years. And the serpentine belts while quiet and more durable than flat belts, still stretch out over time causing stalling of the brush on the carpet. Not so on the Aerus.
Jon
I reply:
I have two generic hoses, one of which was with my Diamond J when I got it and one was with my Diplomat LX. The slide on the one I got with the Diamond J stays closed reasonably well on its own but the other one needs a little help. I just use one of those short, fat rubber bands they put around bunches of broccoli at the grocery store. They fit snugly against the suction relief, stay put nicely and are easily replaceable when they break or deteriorate.
Knockoff
This isn't really a knock off. There is a few companies who have machines like this.
I so Luke the styling and improvements made.
Knockoff
Mike
I had that machine on display at the Vacuum Collectors Convention in September. The retail price is several hundred dollars less than the Aerus Classic, and the Clean Obsessed has more attachments than the Aerus. The Clean Obsessed also has more suction and uses HEPA bags that the Aerus doesn't come with.
I don't understand Aerus's thinking on this. They have a good product, but they stubbornly refuse to innovate even on something as simple as the bag.
Perfect C101
I miss the Perfect C101 all-metal version. It's basically the same as the C103 just hammertone steel. I know they cost a bit more, but they were definitely more solid. Did they not sell well? I actually traded a Silverado to get one.
Perfect C101
I have the C101, it's a great vacuum. Looks very much like an Electrolux 1205 or Super J, it's metal and has a two stage motor that is quite powerful. I also have the C103 which is the plastic version, that's very similar to the Clean Obsessed version, same motor I think, I would say it's more powerful than the Aerus classic, though the classic is also a great machine.
Mike
I had a look at the Perfect C103 white version of this vacuum a few months ago, as one was in at a local vac shop for repairs as I was picking up some parts. Yes, it is a nice vacuum, BUT it also has some drawbacks.
The plastic ring on the exhaust filter that mounts it to the canister, and where the air enters the filter, is at the top end of the filter - so the exhaust air wouldn't distribute evenly across the filter area surface and the filter wouldn't get dirty evenly, meaning that filtration would be compromised as the filter wears and gets dirty. Compared to the original Electrolux after filter that has the plastic ring in the middle, and the exhaust air spreads evenly across the surface area of the filter, so it gets dirty evenly and avoids the problem the Perfect exhaust filter has. You could put a Electrolux filter on the Perfect, but the filter lid won't fit on though. So you would have to find some way to keep it from flying off.
In addition, there is no friction ring on the exhaust opening to keep the filter in place. The plastic ring on the exhaust filter just fits loosely. If the filter lid wasn't in place, the exhaust filter would blow right off, meaning the exhaust filter isn't sealed to the canister at all! Also, because of this, and that they are using the metal body hose connector on their hoses, there is no way you can use the vacuum hose on the exhaust port and use it as a blower. That's a MAJOR disadvantage compared to a Aerus Classic canister!
The generic electric hoses that Perfect uses are nice, but are known to have issues with the screw holes and sliding suction control valve on the hose handle failing over time. And who knows for how long the genuine Electrolux metal body electric hoses will continue to be available, plus if you do substitute the genuine hose for the generic hose on the Perfect you lose the ability to turn the powerhead on and off. At least with the Aerus Classic powerhead, you have the switch on the powerhead, so you can use any hose you desire and not lose that feature. Also note that the Perfect powerhead has had issues with quality control in the past and the plastic screw mounts that hold the motor in place failing.
The only advantage the Perfect and Clean Obsessed canisters have is that the Ametek 119995 single stage motors they use is easily buy online or in a local vac shop, whereas with the Johnson motor in the Aerus Classic you are most likely stuck dealing with your local Aerus dealer for replacements.
However, in my humble opinion, I think a consumer would be far better off just buying a used Electrolux Epic 6500 SR, LE, 2100, Ambassador or Diplomat, and refurbishing it with a new Electro Motor double stage motor that pulls 117" waterlift. You're getting true Electrolux quality designed to last that way, and for a fraction of the price of buying new. Even if I had to buy new, I would rather pay a bit more and get the Aerus Classic.
