CFM in isn't = cfm out?
kenc184
SF Bay
I picked up an anemometer for fun. I wanted to check it was functional, so using one of my Royal uprights - an 886 - I unplugged the bag and measured cfm out. First,let me say this was not done with the utmost precision, the vane type sensor was simply placed over the orifice and the orifice area used as the multiplier. 0.025 I think. No "cone" was used to adapt one diameter to the other, this is simply a "does this work" exercise. The measured cfm was insane - around 200cfm. So now, I'm thinking "this thing is garbage".
Royals have a short steel tube adapter for the hose, so I fitted this and measured input cfm, again no real effort was made for accuracy, sensor simply placed over the metal tube orifice - this time around 100cfm. Much more believable.
How can cfm in not equal cfm out?
To calculate cfm, take the airspeed shown on your anemometer in feet per minute and multiply that by the area of the orifice the air is being drawn through or exhausted from in square feet. There are websites that will calculate surface area in square feet from the diameter of the orifice ( intake or exhaust ). Take that product and multiply it by 0.8. The reason for this is airspeed at the center of the opening is faster than airspeed at the sides of the opening due to the boundary layer of dead air that clings to the sides of a tube. Airspeed increases as you move towards the center of the airstream. The rough rule of thumb therefore is to take cfm you calculate using the highest airspeed value and reduce it by multiplying by 0.8.
See what you get using the correct values for the surface area of the suction inlet and exhaust. Then consider there will be some frictional losses along the way.
Thanks, yes I followed the cfm debate - the blunderbusses as dawn would be more accurate between tourself and another gentleman. LOL.
MY point is WHY when I place the anemometer on the intake I get about half the cfm that I get when I put it over the fan case output (bag removed). Both inlet and output are within 1/8" of each other. I was not looking for a precise number just trying to figure out why cfm in was half of cfm out? Certainly cfm out feels significantly more fierce than the suction at the input but how can this be?
Are you measuring suction side cfm right at the opening in the fan case with the nozzle removed? And using the correct area of each orifice when making the calculation? If you are trying to measure airflow under the nozzle you will not get an accurate number.
Both the outlet from the fan case, and the metal "stub"adapter for attaching a hose to a Royal inlet" have similar diameters. The Royal hose isn't attached like a Kirby. And again, I am not looking for a precise measurement at this point, just trying to understand WHY apparent input cfm is around 100 and the apparent output CFM is around 200. How can cfm in not be equal to cfm out. Certainly one can FEEL the difference, the input suction is stout, but the outlet is hurricane force! To reitierate: I am just trying to determine if this anemometer is behaving correctly or not, it's a $50 Amazon Chicom product so one never knows.
Once I develop some faith in it, I will start worrying about accuracy.
There is a problem with how you are measuring airspeed and / or you are calculating the area of the inlet and exhaust openings incorrectly. May I see a photo of how you are measuring suction airspeed. I don't know Royals as well as I know Kirbys but you need to get the anemometer right in front of the fan on the suction side. If the nozzle is not removable like a Kirby, then you will have to remove the brush roll to gain clearance and hold the anemometer in front of the fan opening.
1/8" difference could explain a lot of what you are seeing, depending on which side is larger. I don't know how big those ports are, but a 1.125" diameter circle has over 26% more surface area than a 1" circle. Add in leaks and imprecise measurements and I don't think there's much mystery. If you want more accurate measurements, attach a short hose to each of those ports when measuring and seal it up with some tape, and also check for other air intake paths, like past the motor or around the interface between that intake port you showed and the roller brush area.
From memory one port is 2-1/4 and the other 2-3/8 so a very marginal difference, not one to explain away a 2:1 ratio of cfm.
Let me ask a question. Are you reading CFM right off the anemometer, or are you reading airspeed in feet per minute and calculating airflow based on the areas of each opening? Those fan type anemometers base their "airflow" number on the surface area of that fan, which is much larger than the surface area of the two orifices, suction and exhaust, you are measuring. If you are not calculating the airflow based on airspeed times surface area times 0.8 you are getting incorrect airflow readings.
