Well, I finally broke down and had a central vacuum installed at my new home in Palm Springs. I was going to wait but decided that this fine sandy dust that permeates everything requires almost constant vacuuming. I have had central vacuums for 40 years. The first being a Filtex. I am posting this on the vintage forum because while the actual vacuum is new, the tools are vintage Filtex. I am not going to get into which units (bagless or bagged) are better. As far as I am concerned that is a matter of personal preference and won't argue. I am a bagged guy and find the MD units great. Lamb motors and Honeywell relays that are easily replaced should the need arise. I always put in the largest unit. In fact the install is done here and waiting for the electrician to run the 30 amp 120V circuit over to the unit. This thing will suck the paint off the walls. I have never experienced any diminishment of suction with this unit and find the bag replacement process easy and clean. To each his own, if you like bagless units, more power to you. The main thing is that a central vac for heads down vacuuming can't be beat by any portable vacuum.
I am sooooo glad that Owen Perkins the Central Vac guy (and wonderful person) suggested that I swap out my MD S5 SilentMaster unit in St. Charles for a vintage Filtex unit and take the SilentMaster with me. Did so. So here we go. Got a great installer out here last week. He had the installation done in less than 8 hours and did a great job. I ordered special brass inlets. He had his daughter helping him crawling the attic and running the pipes. Great job. These inlets now run through the house. The first central unit is the high-end Filtex I left in the St. Charles house and the second is the unit I brought with and installed here.
