Hi, I've been reading the content from you guys and thought I'd reach out with some specific questions.
I have an MD Silentmaster S44 purchased new in 2012. Motor died in 2019 and I replaced it with the Lamb 122525. It died again a few months ago.
I was thinking that these motors were not getting anywhere near the hours rated (we don't use it all that often but there is no way to tell actual hours). I was reading about replacing with other units, whether it be another MD, Drainvac, Cyclovac or Vacuflo (or even the OXO - oh no!).
So for S&Gs I decided to check the brushes and I've found one to have maybe 1/4" of carbon - and the other - gone! So I'm thinking maybe it was my fault all along not checking/replacing brushes but I didn't think I was even at 300-500 hours???
So, the rotor does look dirty but not really scored so I'm thinking now maybe I should just change motor out one for time for the latest 122685 for $150 (central vacuum online - is that place reputable? It is $75 less than MD direct). I'm also thinking about replacing the circuit board just so everything is new.
So my questions - about your recommendation... would you just refresh the parts for around $250 and just make sure in the future I check brushes every few years or would you recommend still replacing the whole thing?
The can is still in decent shape except for the foam is disintegrating. Is is possible to remove and replace that foam?
Thoughts/Opinions?
As fyi home is around 2900 sq ft and I have 3 inlets with longest around 50' of pipe. I was going to ask about bottom motor design, bags, etc. but that would not be necessary if I just refurb this unit... I live 10 minutes from Gator/Think Vacuums and was not impressed. Best option in store was a Drainvac for 1300 bucks.
Thanks!
Thoughts/Opinions?
Thanks!
