Can't figure Royal Metal uprights out
97widerider
Indiana
Hello all, been "collecting" quality vacuums for about 5 years now. Usually find them at thrift shops, set out at garbage etc. Have found a few gems like a Kirby Heritage II that just needed a new hose for the bag. Have two craigslist finds, a 2002 Kirby G5 and a 2007 Kirby Sentria. Cant understand why people selling perfectly good Made in USA vacs for pennies on the dollar. Both were like new.
Anyway, I have always wanted a Royal metal upright. Found a 4000 model (year 2000) at a thrift shop for $15.00 Needs a brush roller and belt. Cleaned it up with some mag polish and it really shines. I am guessing it doesn't have too much useage due to the red rubber handle looking like new still and the light bulb still works. Motor sounds great and it separates the carpet from the pad with it's suction. I tried taking it apart but ended up stripping a screw so that will have to wait until I really need to get into it.
Now to the issue. I am learning that Royal doesn't have product support like Kirby when it comes to parts. Looks like I am limited on what can be fixed or replaced. I mean if I need new carbon brushes I can't seem to find anything for my specific model. Roller bars are very expensive and not as plentiful. Light bulbs can't be found. My 1988 Kirby Heritage II had every part available still, at least the ones I needed.
Furthermore, why doesn't my 4000 "Classic Edition" show up on any Royal manufacturers time line? I found a very comprehensive one on this forum before but not a word mentioned on the 4000. Why do Royal's have 'Commercial Quality" on them but aren't pushed as commercial vacuums but homeowner vacuums? Their commercial line looks the same but a different color, orange is it?
Finally, how long can I expect this vacuum to last with vacuuming three bedrooms and a living room rug about twice a week, oh lets say 5- 10 minutes of "on" time twice a week? Of course we don't know what it's been through thus far.
I know I threw a lot at you first post but so many questions.
Will unlike Kirby,royal has been bought and sold a few times or something like that. Somebody else can clarify when the Chinese company TTI purchased Royal.
But basically TTI is washing their hands of the metal uprights. Due to manufacturing costs and lack of demand. As you could imagine in 2019 there's not really a market for them past collectors.
Generally speaking of ESSCO doesn't have it it's not available. It must be purchased second-hand or New old stock somewhere.
Hope that helps.
https://www.essco.net
I hope my Royal 884 outlasts me...
I'm only 25, I'm sure it will but I would be heartbroken if it conked out with no way to fix it. I couldn't bear the thought of trashing it even though I only paid $10 for it at a thrift store. When I bought it, I actually walked away from it, thinking that "no, I don't need another vacuum" (I had just purchased a Sentria I), but I couldn't walk away from it. I'm glad at the fact that I decided to take it home.
It's older than I am (it was manufactured in 1988) and still does a great job. Fortunately mine is old enough to have an oil port for the rear bearing (unfortumately none for the front), so I guess a regular oiling will extend its life. However, it is a real problem that parts are not as easy to obtain vs. something like a Kirby. I will say that I was able to find a Royal brushroll for $25, which is in line with what Kirby brushrolls are priced. I think that the pre-G Series Kirby carbon brushes are compatible with Royals, but not 100% sure on that. As far as everything else is concerned, like fans, armatures, bearings/plates, etc., it seems more or less like "cross your fingers".
Local vacuum shops should carry Royal parts, mine here do. It should last you forever, they were only sold for industrial use and they are built to take it.
"Cant understand why people selling perfectly good Made in USA vacs for pennies on the dollar. Both were like new."
Because a fool and his money are soon parted.
"I mean if I need new carbon brushes I can't seem to find anything for my specific model. Roller bars are very expensive and not as plentiful. Light bulbs can't be found."
I believe most Royal carbon brushes should fit, and they should be available through ebay. If not, brushes are literally just chunks of carbon - any old thing will do. Measure them and search ebay with the measurements and the term 'carbon brushes.' You may have to search for the nearest fractional size and nearest metric size to turn up something. Most brushes come in fairly standard sizes - as long as they look similar - and don't be afraid to buy brushes a little too big and shave them down with sandpaper or a razor blade. As long as they fit well in the brush holders - not too tight or too loose - slide easily, and have roughly the proper springs behind them (you can always reuse the original brush springs [I'm assuming they have springs]), they will work.
As for light bulbs... don't they just use a standard bayonet appliance light bulb? aka 'vacuum cleaner light bulb'? I'll bet it's similar to the aftermarket car parts industry, where if you're searching for something very specific, but for a very common car, and come up with absolutely nothing, it's often because the part you're looking for is so common and universally used, that it's rarely, if ever, associated with the particular car you're searching under. Hopefully someone else will chime in and let you know what kind of light bulb it uses.
Also another helpful tip with an automotive allegory: when you're looking for parts for that weird car that nobody really knows exists, you usually have to find its nearest sibling and look up that instead. Luckily for you, Royals are all very similar to each other. They're kind of like the VW Beetle, 'evolutionary design' aka, they never changed anything. I'll bet if you need a part, and you just search for 'Royal' instead of 'Royal 4000' the stuff that turns up will probably fit. Hopefully someone else here can let you know what's the nearest relative to the 4000.
I use Chinese made led bulbs ( single or double contact point depending on your model .... works beautifully. Enjoy...with MORE light now
Well, thanks for all the replies. MadMan, you make a lot of sense and I will explore the route of the "next of kin" parts so to speak. Fortunately everything works to include the light at this time.
I do find it odd that even with all the different model numbers through the years, they all look similar. However, when I am shopping for a 14" brush roller, the different years/models call for different part numbers. My 4000 model ends in a 4000 but a part number that ends in a 3000 or 5000 will not fit. The vacs that these rollers fit look identical as well. You would think that Royal would find it more cost effective to make the parts interchangeable throughout the model changes.
Anyway, all I need is a roller (which can be had locally for $37.00) and I am on my way.
BTW, My favorite feature for this vac is that I can lock the handle completely horizontal and store in upright is the closet.
97widerider
Derek,
These are the specific replacement part numbers you need to reference for your model 4000:
1-672260-001 = belt (Style 8)
2-673274-000 = revolving brush assembly w/ magnet for brush speed indicator light
I went to my neighborhood vac shop to buy a brush roller and a belt. The patient gentlemen gave me the complete rundown of Royal Company and their history of vacuums. I'm talking 20 -30 minutes worth of chatting.
He says that as an authorized Royal dealer, he was told by Royal that all vacs should have parts available but he is also noticing that many parts are now obsolete. He is also concerned about the current status of Royal vacs and not sure they will be new ones produced in the near future.
He reassured me that he currently has every part for my 4000, if not new then it can be taken from the Royal "junkyard" he has in the back. He confirmed that most models are indeed interchangeable in their parts and it is often a trial and error procedure. He has new motors, used motors, bearings, you name it.
Long live my Royal.
Hey
I just got my royal 4000 it has 10.5 amp motor. The bulb is same as older Kirby's. I'm thinking Sylvania 1560. I couldn't get the led ones to work. It is loud. The carbon brushes are same as early Kirby models.
This royal has drop in motor. Everything's enclosed in housing. I don't have 10amp 1030z but this feels stronger.
Hey
Kirby 505- classic 1 use 1156, all royal vacuums, my older riccar 8650 eurekas sanitairre, most power nozzles,
Just an example Kirby 505 and royal made in 1949 all take same bulb.
Thanks so much for the info ! Sounds like plenty of replacement parts to be found.
Les, are the carbon brushes easily accessible once the motor is pulled? I do not have the model where they are under caps at the rear. If the motor is still out could you possibly send a pic of one?
97widerider
Derek,
The correct light bulb to use will depend on if the machine has the non-drop-in motor (7.0 amp or lower, with carbon brush access caps on the motor housing) or if it has the drop-in type motor (7.5 - 10.5 amps)
Use part no. 1-880629-000 (a 120-volt bulb) on all Royal metal uprights rated 7.0 amps or lower. This is what your 5700 (9700) would use.
Use part no. 1-725629-000 (a 12-volt bulb) on all Royal metal uprights rated 7.5 amps or higher. This is what your 4000 would use.
Ok, those part numbers don't come up with anything unless you omit the beginning and end numbers. So here:
880629 - 120v
725629 - 12v
Looking at the 12v bulb, apparently I was wrong, it is NOT an 1156. That would make too much sense. Instead they basically used the same bayonet base as the 120v bulb, but put a 12v 1156 bulb into it. In other words, the base has two contacts on the bottom. There's only one listing on ebay for it, and a couple here and there. So not impossible to find, but not exactly plentiful either. I'd assume vac shops or vac parts websites would carry them.
The 120v light bulb I swear looks like any ordinary "appliance light bulb" or "vacuum light bulb." Correct me if I'm wrong.
Me, personally, it would bother me that those 12v light bulbs are hard to get. I'd just modify the bulb socket to take a NORMAL 1156 bulb. But hey, that's just me :3
Hey
The motor is similar to s cannister vacuum Motor. The bulbs a Sylvania 1156. The carbon brush from 505-d80 fit perfectly. The carbon brush I'll send pics of. I have and pretty sure kelton got bulbs I mentioned. There is 2 bulbs. One is a little longer than stock 1156 bulb and other is same size.
eBay Kirby needs sales carbon brushes. Led I'll provide link later when I get home.
Amebush lamb makes most motors that's why Kirby carbon brush fits.
I'll check the belt out some parts may be interchangeable but belts you the right belt always get oem.
I really appreciate that. I’m grabbing some brushes to keep on hand. I plan on keeping this vac running for as long as I can. I will be visiting my folks in another state this weekend and they live by a few Peddlers Malls (basically a flea market that’s indoors) and am determined to grab either another Royal or older Kirby.
Pic
Hey
I took pics. The normal Kirby are small carbon brushes the bigger brushes on legend 2 are next to royal carbon brushes. I have been confused as I have been working on 3 older royal vacuums lately.
These carbon brushes are the biggest I have seen.
The copper coil is attached to back of brushes. The spring I took off and put back on in pics.
The top of the motor housing is 4 numbers on each side.
For now go with Sylvania 1156 bulb. I don't have led bulb on this yet as I just cleaned it up. Check carbon brushes but you are probably good because those suckers are huge.
The interchangeable royal Kirby parts are for almost every model except this model.
So just stick with regular light and check carbon brush but there probably good.
The royal we both have has biggest motor I've seen in uprights. I know amebush lamb made the motor. So ordering motor parts order from amebush lamb as this is only 10.5 amp royal upright your not going to find parts.
The 14 inch royal brush roll fits.
The bearing plate and fan remind me of rexair rainbow motor and amebush lamb compact interstate motor.
Just a note of warning, if you try to use an 1156 bulb - which has a single contact on the bottom - in a socket for a bulb with two contacts on the bottom, it could end really badly. Before putting any bulb in, LOOK into the socket and see if it has two contacts on the bottom or one, and match the bulb to it. As long as you match the number of contacts in the socket, you might blow the bulb, or it may not work if the bulb is wrong, but your vac will be safe. Make CERTAIN. If you put an 1156 in a two-pin socket for a 12v light bulb, if could short out the windings in the motor.
Of course, I don't know which bulb you need. It's always best to look before you leap. Would be nice if it was an 1156, though. Because those can be had by the dozen, from ebay, amazon, or any car parts store, for very little money.
The bulb in it actually works, I don’t want to take it out because with my luck that would jar something loose and it wouldn’t work upon putting in back in. I figure once it’s shot, I will pull it and hopefully there will be a number on it. Really I don’t need a light on it because the weak little bulb doesn’t really put out enough light to serve a real purpose anyway , especially with standard house lighting.
Fair enough.
But anyhow, I was rummaging around some junk in my shop today, and I found a 1004 light bulb. Two contact base, single filament, 12 volt. It *should* sub for the 2-pin 12v Royal bulb. It's a very old fashioned automotive light bulb, but you can still find them online for very cheap. RockAuto.com wants only $0.23 each (plus shipping). Just thought I'd let you know.
Hey
My numbers are off but dual bayonet bulb from 505 fits up to d80. The royal vacuums from my 1949 up to my 1996 the dual bayonet bulb fits. So my number is but 1650 is oem correct bulb. So being logical as you say would you recommend 1004 bulb or 1650 oem to Kirby. I was off on number but like meant dual bayonet bulb. I didn't mean single bayonet. I wouldn't recommend 1004 bulb either it could short out a vacuum just as good as a single bayonet bulb would.
So
I'm just messing with you madmen but you know I meant double bayonet as 505 through classic 1 take double bayonet bulb. So my intention was good. I also retracted my recommends for motor.
The vacuum cleaner is a beast. When you vacuum raise nozzle to Max height. You will still be sucking up quarters 10 ft away. Keep it away from throw rugs. Keep away from animal toys. We had like a 4-5 inch rat and it frappeyet it. So be careful it eats everything.
I have a coworker who orders from Rock Auto all the time and will have him order me a few bulbs for later. That is good info, thank you!
Lesinutah, I was at a Peddlers Mall today and found a Kirby Vacuette in great shape for $10.00. I didn’t buy but was researching it and found an older post where you were looking for one. I’m thinking about going back to get it but am curious as to your opinion , or anyone’s, on them. I need one to vacuum my stairs that is a medium pile carpet. I need something with some power.
@lesinutah u said u couldn't find an led that worked. the ones u tried were they 12v ac or dc. when i was looking for a replacement led for my kirby heritage the first one i got only supported 12 dc power when powered on it did work but the light was very dim and flickery. the Kirbys actually use a 12v ac bulb i'm betting these royals do as well.
here is a link to one on amazon u can get for 6 bucks https://www.amazon.com/gp/product/B008I0CRLO/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Hey
The reason I couldn't get it to work was the bulb was right there was a piece stopping the bottom of the bulb from connecting. The screws to get to the bulb are on verge of stripping out. I have the bulb just not in a rush to put led in as barely got 2 others screws loose that we're almost stripped.
If it's this thread Kirby vacuette buy it for $10. It is a great hand vacuum it agitation and suction are very good. I have a good 10+15 hand vacuums and this and my Iona dirt raider are best ones. Iona is like twice the size of other hand vacuums. $10 is a steal.
The (stupid) idea of using a 12v light bulb in a 120v appliance works because they put a secondary winding into the motor that works either like a generator (alternator, technically) or a transformer to create 12 volts. ((tfw when I realize there may not be a difference.)) Either way, it'll be AC. And the typical LED replacement 'bulb' for automotive use is designed with the notion that it'll be receiving good DC. So such an LED bulb won't really behave properly on AC, as it'll basically flicker on and off with the sine wave.
Unless, of course, the LED bulb is designed to be used with AC, and it'll have a rectifier and smoothing capacitor inside of it.
