rivstg1
Finally got it! Galaxie Prestige 990( a Royal 888 with different name). I had looked at it at a thrift store, waited till today when it was half off ( chancing it , no doubt, it could have been bought by someone else in the one day interim). It’s very quiet surprisingly . I serviced it ( checked crushed, cleaned commentator , set brushroll height , changed belt,& oiled the ports) as well cleaned and polished it. I always wanted a removable head Royal ( like Kirbys) so this was a great find. It shows 400 watts, is that a 3amp rating? It’s nothing like the Royal 4000 (9amp) I have, but very pleasant to use.
Polishing made quiet the difference !!What ya’ll think? with some real elbow grease and determination , this 1972 model turned out well.
Check out the wild adaptation of the power head plate compared to a Kirby. In using it, I find it more cumbersome to remove/attach than a kirby . The belt lifter needs the ‘hook’ that Kirbys use to better grab the belt. It just has an ‘arm’ and most of the time it catches the belt right in the middle of the belt. That action hastened a belt breakage ( older belt though).
It’s odd though , the valve nipple that is sucked inward when a good ‘seal’ is made with the nozzle to the carpet has not been ‘going in’ much unlike all my other Royals . Is there an possible issue with that belt cover/nipple/seal not working right? I can’t seem to get it to retract much ?
