Brandywine Eureka cordaway
hooverkid
PA,USA
Hey everyone! I have Eureka Brandywine cordaway upright and wanted to know how long the cord is supposed to be. I know mine has a replacement plug and I think the cord may have been cut short because it's only 12 feet long!!! If anyone knows I'd appreciate it.
That cord reel was made by a company called.....
Cordmatic. They also produced cord reels for the earlier luxes (meaning the XXX, and LX, LXI), as well as the first Hoover Portable with cord reel, before Hoover began to make them in house.
My recommendation, is to just find a real nasty beat up Cordaway, one that is non all original, besides the cord, and as you probably know, the cord reel is a one piece setup, with two set screws. Just then switch the complete cord reel.
Or find a beat up Eureka canister with the appropriate cord, then pry off the black cord reel cover (the one that has the round copper connections), and just insert the new leads, and either sodder, or do what you have to, and rest the black cover. Make certain the leads are not touching eatchother, everything is clean, and re wind the cord in the original direction, and retighten reel....
I hope this gives you some direction. Good luck! A little understanding and practice goes a long way with things like cord reels. No need to be afraid, just use common sense, and have courage...
'Brandywine' Models List
I got curious and wondered how many Brandywine-colored Eureka models there were. Here is a list that I made. Even if it's incomplete, there are quite a few! Please add to it if you can. I know there was a classic-style hood upright with headlight, too, but don't know the model number (guessing it was a Kmart 600 Series). There was also another Wide Track.
Btw, is 'Brandywine' the company's color name or Vacuumlanders'?
Key:
PT - Power Team; D-a-N - Dial-a-Nap; trapezoid (Princess-shape); teardrop (canned ham); trunk (Sweet Sixteen shape)
1. 671 PT
2. 1279 trunk PT 9.5-amps
3. 1289 teardrop PT
4. 1290 trunk PT 11-amps
5. 1452 D-a-N Vanguard-style hood
6. 1443 2-way D-a-N non-headlight classic-style hood
7. 1514 trapezoid PT
8. 1756 trunk PT
9. 1761 Quiet Kleen trunk PT
10. 1770 trunk PT
11. 2087 ESP D-a-N
12. 2097 ESP D-a-N Cordaway
13. 3710 trunk canister
14. 4060 ESP Wide Track Cordaway Box Top
15. 3334 trapezoid canister (?)
That's interesting
because I have a 2087 A Brandywine ESP that only has a 12 ft. cord, not cordaway. I always thought that ESP's were upper tier. Doesn't appear to have had the cord cut. Hmm.
eurekaprince,
"On closer inspection" as they say, it looks factory but on the plug there is a diamond shape with PWC printed across the top. Wow 20 and 40 ft.cords were available? I need to go shopping because... thank you for that info! The fact that even this cord has been taped about mid-way adds the possibility that this cord could be grafted also,thanks!
eurekaprince,
At least two of my Eurekas also have PWC on their plugs; albeit the 1960s one lacks the rhombus outline. I think the cords were made by what was originally the Plastic Wire and Cable Corporation when it began in 1948 in Jewett City, CT. According to a newspaper article, Triangle Wire and Cable, Inc. of Lincoln, RI purchased it in the early 1980s; then the name was changed to Triangle Plastic Wire Company. The plant was closed in 1995. It could be that Eureka then went with Triangle for its electrical cords.
Did a little research on the company. Apparently it closed down many years ago. The factory was gutted by a fire and more recently the site was bulldozed. It is also heavily contaminated.
Do you know what it is contaminated with? Maybe chemical leaks.
They were making plastics. All kinds of benzine, toluene and methyl-ethyl bad stuff. Until the 1970s or so companies routinely dumped liquid wastes into unlined ponds or barrels out back and the stuff leaks into the ground often contaminating aquifers. Back then nobody realized it would become a problem and there were often no laws requiring the stuff to be disposed of off site in a specialized facility because the facilities didn't exist. Dump it in the back forty, dump it in the river or lake. Dump it outside Bakersfield. That's how it was.
Paul, I have a Eureka model 1290. Its the same as the 1289 but 11.5 amps and has a two speed switch with a blower slider port. It's a canned ham shape, not a trunk Sweet 16 body.
Triangle plastic wire company is an interesting name.
I agree. Curiosity got the best of me, so I did some research and found that the original company, based in New York, began in 1916 producing three products: armored conductors, flexible steel conduit, and non-metallic conduit. Now 'triangle' makes more sense.
Mike, Thanks for the correction. I have wondered what the difference(s) of the 1289 and 1290 was/is besides a slight difference in motor amps. I wonder if the 1289 has the same features as you mentioned but has a different motor (e.g. single-stage versus 2-stage).
Are you aware of any other electric floor care appliance companies that used PWC cords? The only other electrical cord supplier I have ever known about is the Belden Company that made cords for Electrolux back in the day.
Poking around the internet trying to find out about PWC I discovered there were several more companies making plastic covered wire products in the same town as PWC. It is alomst as if that was the town's main industry.
They were competing in a national market. Lots of buyers to keep them in business. Look at the town of Dahlonega Georgia. Most of the carpet made in the US comes from that town but there are plenty of firms competing nationally.
I find that interesting. I would think that having so much competition in one town would drive the prices right down and lead to there being one large one and 1-2 small ones and the rest fizzling out
You are so well-versed in both national and international manufacturing. Thanks for sharing your wealth of information.
