Bought A Dyson PencilVac From Japan (Review Inside)
vac14012
Florida
I will preface this review by saying I live in a 1700 SQFT house, so obviously it wasn't designed for a house of this size. Being designed for smaller Japanese style homes. Battery life is only like 30 minutes or so give or take what power level you're on, so obviously it won't be able to do a full house cleaning of this size, so I won't be giving it any negatives on that front. But I wanted one anyway out of curiosity for new technologies, especially since it's the first and only Dyson without a cyclone system.
Pros:
  • Extremely light weight as advertised, zero hand strain when in use compared to other stick vacuum form factors, say my Dyson V15.
  • Cleaner head works as advertised with zero hair tangles. Any large hair is rotated outside the cones into a ball and you can then vacuum it back up.
  • The lightweight nature of the vacuum, alongside the brushes rotating in different directions, gives the illusion that it's floating. So it's very fun to use and whizz around the house.
  • Dust is compacted in a similar way to a bagged cleaner. I was able to store a lot more than I was expecting, considering how small the bin size is.
All of the cons for are when it comes to emptying the vacuum. Unfortunately it's not as easy to empty and clean as Dyson claims in the videos. I vacuumed up cat litter and noticed quite a lot of it went to the backside (shown in Picture 2) of the bin. I cleaned out the vacuum before I thought to take pictures, so I'll have to come back next time to show. But I had to take the bin off and dust the backside of the vacuum with a duster. I'm willing to accept some form of user error here, but I'm not sure what it would be. I did take off the bin/metal shroud piece to have a look at how it works before using, so it's possible I didn't place it back on tight enough, allowing dust to go behind. I also noticed quite a bit of small dust was stuck to where the cleaner head connects to the vacuum, which fell on the floor when I removed the cleaner head. Lack of cyclones also means you're relying entirely on the pleated filter and shroud, so prepare for having to tap them against a garbage bin, in a similar way to other non cyclone bagless cleaners. (Dyson does show this in the maintenance instructions on YT, so they're not shy about it tbf) But all that combined means even in a small area as designed, the maintenance is still going to be way more annoying than say a Dyson V8 or V12.
Overall I will say it's still a very fun machine, and I'm probably going to enjoy using it for awhile. But it feels like the non cyclone technology and tiny form factor wasn't 100% ready for primetime yet. The new Dyson Piston will be a much better product I imagine with similar anti tangle cone technologies, and dust compaction etc.
    322.7 KB
    387.4 KB
In Japan non-cyclonic bagless vacuums with a thick pleated filter at the back of the removable dust chamber ( most often with a fine mesh screen in front of the pleated filter to catch the bigger chunks ) are pretty popular. There is usually some sort of scraper thingie built in to knock stuff out of the filter and back into the dust bin. I think every major company makes or has made them at some point. Our Japan market Panasonic Rulo robot vac has that kind of set up. Seems to work. I buy these vacuums used from Japanese internet flea markets and they are surprisingly clean inside. The dust bin is dusty but lift the dust bin out and all the rest is clean. The filters do their job far better than you would expect.
Vacuumed another area, here's some pictures of what i'm referring to, with dust going behind the bin. Also the pin connector gets covered in dust. Not sure if any of this would effect performance, but definitely cosmetically ugly.
The cleaner head itself is amazing though, I would totally use it on my V15 if I could. So it's a shame the actual vacuum itself isn't quite there yet.
    186.8 KB
    166.8 KB
    150.9 KB
There is a fundamental difference between the separation method on those other products and the Pencilvac that's worth appreciating. The Pencilvac employs inertial separation across its mesh, whereas others rely on mechanical first stage separation with their mesh. That mechanical separation is similar to the mesh screen following the first stage cyclonic separation that Dyson pioneered by turning air on entry to the bin and that every manufacturer of bagless products has now duplicated, due to its effectiveness. Its weakness is that it's susceptible to mesh blinding that is alleviated with Dyson's pioneering inertial separation approach.
Products which rely exclusively on mechanical separation are, in essence, effectively filtrationally equivalent to bagged machines of old, and their resistance to air increases as a function of dust loading, as well understood. The inertial separation of the Pencilvac brings advantages over mechanical separation to rate of change of air resistance as a function of dust loading for particles larger than ~150 µm (maybe a bit smaller owing to inertial benefits), since the mesh is aerodynamically washed. The lack of a supplementary intermediate filtration method before the filters due to space restraints, that's otherwise currently provided by cyclonic filtration (whose days are numbered...), means the filter—a mechanical method—will clog at relatively greater rate in the presence of smaller particles (sub ~100 µm) that are not captured by the mesh mechanically or inertially. That intermediate method would substantially extract down to of the order of 1 µm in the best products.
The filtration technology in the Piston is more interesting, and beyond that, even moreso.
The Japanese were making bagless vacuums with a mesh screen in front of a pleated filter before Lord Diesoon was even out of secondary school : /
I suspect you're right. But that's not what the pencilvac is beyond its cosmetic exterior. Its filtration operates differently for particles greater in size than about 100 µm, which was the point being made above.
Having used the PencilVac more today, it's genuinely a great hard floor cleaner. Picks up everything without problems, and the edge cleaning is awesome.
The biggest design flaw is the top of the cleaner head that connects to the vacuum. Dirt and (particularly cat litter) likes to build up on the outer walls of the tube and can fall back on the floor when you remove the head to empty the vacuum. So I've taken to removing the head while the vacuum is over the garbage. Annoying but solved it.
Overall I still think it makes vacuuming very fun.
There is actually some evidence to support problems like this. This product assumes you're mostly cleaning up natural household dust and pet hair etc., not artificially placed sand pits etc. that some of these utter geniuses use to 'test'. In other words, what you might find in homes in the target geographical area. The mains-equivalent vacs, like the Piston, wouldn't suffer this problem.
Tbf, I haven't had a giant pile of cat litter fall back out like in the video with the sand. Just some smaller amounts. Even a corded vacuum cleaner could struggle with sand though. The fact that it even managed to at all, despite falling back out when emptied is still impressive tbf imo. It's just not really the right device for it, so unfair to criticize it for that.
Anyway all this being said, it's absolutely fantastic at general dust/dirt/hair/debris found in most households. I'll just continue to use my V15 for cat litter.
For some of us kitty litter qualifies as natural household dust, etc.. Cats track it around surprisingly far from the litter box. I keep our litter box in our master bath ( long story why ) and have to vacuum twice a day. I have a dedicated bathroom vac, a Japan market Panasonic MC-PA21G.
