Bissell PowerForce Compact 2112 Honest Review
crazykirbydude
Lexington, KY
So about a month ago, I bought one of those little PowerForce Compact Wally-World specials for kicks and giggles (I like to test cheap vacuums occasionally). Over the course of a month, I have grown to despise the damn thing. Also, keep in mind that this vacuum is no longer $35 like it used to be. They have now jacked the price up to $50, which is only $4 cheaper than the full sized Bissell PowerForce Helix 2191, and only $6 cheaper than the full sized Bissell PowerForce Bagged 1739. I know this is one of the cheapest new upright vacuums out there, but that doesn't excuse the numerous design flaws of this machine. I will start with the few pros of this vacuum.
PROS:
Lightweight
Cheap
Decent tools for the price
Very compact
CONS:
Extremely flimsy feeling
Loud and shrill
Extremely short cord
A brush roll so aggressive I thought it was going to tear my carpet up
Not designed for taller people
Extremely weak airflow
A hose so short that the vacuum topples over any time you try to use the hose
A very inefficient separator that loves to trap larger debris
Horrible filtration
The cleaner head is around 10 inches wide, but there's only around 8 inches of brushroll
Completely useless "auto height adjust"
Hopeless on hard floors
You might be saying that I'm being too hard on this cheap vacuum, but keep in mind that I find the Bissell PowerForce bagged (only $6 more) to be a decent, usable machine for the price. This vacuum is so pitiful that an old Regina ElectrikBroom PowerTeam could outclean it 10 to 1. I didn't expect a Sebo, but I expected something usable. I don't get why Bissell even still sells this model when the full size version only costs $4-6 more. I will attach a picture of the offending vacuum.
There are still some bargains if you know where to look. The aforementioned Bissell PowerForce Bagged and it's upgraded version, the Bissell PowerLifter Pet Bagged, are decent budget options, at $56 and $149 respectively. The Sanitaire EUKSC679J is a good option as well at $109. Of course, neither of these vacuums will clean as well or last as long as a high end machine, but for brand new vacuums under $200, they are viable options. I will attach links to all of these vacuums as well as pictures.
Bissell PowerForce Bagless (Walmart exclusive)
https://www.walmart.com/ip/BISSELL-PowerForce-Bagged-Upright-Vacuum-1739/104757366
Bissell PowerLifter Bagged (also sold as the CleanView Pet Bagged)
https://www.bissell.com/powerlifter...49&gclid=CNrq3fKh5OcCFeiXxQIdyJYJSQ&gclsrc=ds
Sanitaire EUKSC679J
https://www.amazon.com/Sanitaire-Co...ywords=sanitaire+vacuum&qid=1582343821&sr=8-3
The Bissel Powerforce bagless version is sadly every under $50 bagless vacuum that you can buy brand new that has been put on a photocopier and copied over a dozen times with each copy degrading more and more in quality from the first.
The bagged model is very very good, and it often goes on sale off and on for $30 brand new on some websites.
Bissell Powerforce Compact Tests
I've done extensive testing on a 2013 model, which is older than what is pictured above. Bottom line: incredible on my medium pile carpet. It easily bests vacuums at 10 times its price. I nabbed it used at a thrift store a few years ago. It needed a belt and the hose unclogged. Here's a link to the 12 video playlist.
Bill
I actually used to have one like that. It was a trash pick, and I had it until one of the wheels broke off. Performance wise, it was similar to the newer model. They were barely worth $35, let alone $50. I'd definitely shell out the extra $6 for the bagged full size upright.
My mom bought one of those a few years ago when her old upright broke. She took it back because it was too small to clean a whole house of carpet. I thought it was kind of cute but it never got so far as out of the box. At the time I think it was still $35 (around 2017 early), I couldn't imagine paying $50 for it! She ended up getting a Hoover Windtunnel 2 Whole House Rewind instead.
She did the same thing when she got her prior vacuum. She was going to get the Eureka The Boss Lite because it was cheap and then realized it was a tiny, tiny machine!
The bagged Bissells are nice machines for the money. I don't have much experience with them but I did like the older Powerforce bagless machines as far as being lightweight and not too loud. The main drawback was the nasty bagless system. Of course the bagged system eliminates that. And from what I hear Bissell's Febreeze bags actually do a pretty good job of not leaking.
Ok, so I used the Bissell PowerForce Compact again today and found another issue. This vacuum will not clean anything that is not right in front of the cleaner. No edge cleaning whatsoever. I have to use the tiny hose and weird wand to clean up particles that are close to my baseboards. Also, upon inspecting the dirt cup, my suspicions that this vacuum eats the carpet turned out to be true. I saw quite a few torn up carpet fibers.
That is a problem with the stiff bristle nylon brushrolls that exist on Dysons as well. The vacuum design relies on those as the beater bar, and it creates friction burns to the fibers and singes them off. I have a spot of low pile carpet on my stairs that is burned in a plowed field pattern from where I pushed too hard while cleaning them using an Aldi Easy Home bagless upright vacuum. Also if you have wool fiber rugs that are old or trampled, a lot of vaccums can tear fibers off. Wool is not that durable.
These weren't just loose fibers, these were whole tufts torn up from my carpeting. It's 3 year old builder's grade carpet, so I think it's already done all the shedding it needs to. This vacuum would be utterly useless without a brushroll. None of my other vacuums do this, including my older Bissells.
Bissell vacuums are "so pitiful that an old Regina ElectrikBroom PowerTeam could outclean it 10 to 1." 🤣😂 That's the best! Wish I had said that in my last review of a Bissell upright.
Not all of them, just the bagless ones. The bagged Bissell PowerForces are actually a pretty good value for the price. But yeah, the PowerForce Compact is awful.
Yeah, Bissell has great vacuums, and mostly all of them work very well. There is just a few models every now and then of their badge-engineered vacuums they put out as price fillers that have been so watered-down they don't do too well.
You cannot hate an entire vacuum brand just because what you read on the Internet, that's very narrow minded logic and a bad way of thinking. You have to actually own and use them for several months before making any judgement - which is what crazykirbydude has done. He actually has a well rounded out report of it.
The Pet Hair Eraser Turbo that HonestJoe posted I actually will be getting soon, that's one of their really good models. https://www.vacuumland.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?39603_14
I also found a Powerforce Helix on the curb a year ago and saved it from the garbage truck, put $25 of parts into it as well as a full motor teardown and tidy-up and she's rockin and rollin like it just came out of the box yesterday.
I also just bought a Zing! canister to try out for my kitchen and hard floor areas of my house - it will be my first modern canister (all my vintage canister vacs are coincidentally entirely Electroluxes - I just love those vacuums to death).
Talk about Chinese junk!
My mom had a Bissell and it was complete GARBAGE! It only lasted 2 years and had terrible filtration and cleaning performance. She aventually got a SEBO Felix that was a million times better.
Ajr2993
You cannot compare a vacuum that sells for $35 to a vacuum that retails for over $800. That's not how it works. They are two totally different vacuums built for different price points and have a vastly different design and assembly. Also - not all of us are rich. Maybe in California that $800 vacuum works for you, but not in the rest of the USA especially for people that live on $1,000 a month.
Furthermore SEBO does not supply spare parts for their vacuums in stores. You have to go to a authorized SEBO vacuum shop that sells those belts/bags, or buy them online. For actual machine parts (housing, brushroll, motor replacement), you have to take them to an authorized SEBO service center for the warranty to be honored. SEBO is still new to the US market, so you will never see them set up outside of major populations. There is only 4 SEBO dealers where I live in Indiana and the closest one to me is 125 miles away. 125 miles!
People that blindly parrot "get a sebo" "get a miele" to anyone asking what vacuum to get fail to realize that they are LUXURY brands of vacuums, like Jaguar or Ferrari. Not everyone can afford them, and not everyone needs one. The long term care and upkeep of maintaining these vacuums - even for people that have firsthand knowledge on how to repair vacuums - is a major exercise in aggravation. The companies have a tight noose around your neck as soon as you buy the vacuum and you HAVE to follow their orders at where and how to repair it (this is for people that buy them retail and have the warranty).
The Bissell Powerforce bagged is far superior to the Powerforce Bagless, but as with all bagless vacuums the problems are usually 100% caused by user error always. You have to clean the filters on a daily or weekly basis and empty the bin every use and keep watch on what you pick up. The last 4 bagless vacuums I got from the trash were all thrown out because they were not properly cleaned and maintained. One had a broken belt, one had a broken belt and a jammed brushroll from rust (picked up water?), another one was packed solid from dryer lint someone trying to vacuum their entire dryer duct out, another one was clogged with several toothpicks and dog hair and a candy wrapper deep inside the suction channel and took a total dismantle to reach it.
I agree with huskyvacs on one thing, you can't compare by price. We all should know that usually the more you buy, they better they can be. Not all the time but mostly. I've personally experienced using some cheaper machines that can outperform pricier vacuums.
Now a couple of things that I'd liked to point out about Sebo since I've used, sold, and repaired them before. You don't have to pay that much for a new Sebo, you can find a used one for a good price and fixed it all up for a reasonable deal to "like new" condition. Just the other day, I was able to find a X5 for $12.99 at a local thrift store. All it really needs is just new filters and it would overall cost just as much as buying the cheapest Bissell.
Just like Kirby for example, there are other places where you can find Sebo parts at. You also don't have to buy them from a Sebo dealer. I wouldn't be too concerned about the warranty on a Sebo, they are very reliable machines because they are commercial grade so it's rare to see warranty work done on a Sebo. At least from where I'm at. Also, Sebo has been around longer than Dyson or Shark in the US. They're one of the major vacuum manufactures in the world today.
Yes Sebo are not cheap machines to buy but again, you don't have to pay that much for a brand new one. You can also get a Windsor Karcher for alot cheaper if you still want to buy a brand new Sebo. Just you'll get less features, warranty, color options, etc. Even though they're still not as cheap, at the end of the day they are reasonably priced machines to own for a long time. I mean many if not all of the parts are very inexpensive to get (depending on the dealer of course). And you can even still get parts for older discontinued machines, not alot of companies do that. Also not to mention that the cheapest Miele you can get brand new would be $200, cheaper than some brand new Bissells that you can buy today.
And I agree with huskyvacs on another thing, lots of consumers would throw their machines out due to the lack of ownership care. It's not just Bissell but even Sebo as well. Heck my X5 that I found the other day not only has a full bag but it also has a clog and there's even dirt on the inside of the bag chamber. I have a relative who owns two Bissell Powerforce Helixs' up at their cabin since 2013 and they still work to this day because they've been given the maintenance that they need. They're not my most favorite machines to use but it's definitely better than not having a vacuum cleaner at all up there. You take good care of your vacuum and the vacuum would take good care of you, simple as that.
Anyway, that's all that I wanted to say here.
Bissell powerforce
Not my favorite vac either. I do like how easily the dirt container can be taken apart and throughly washed in the sink. It’s not like a Dyson with all those screws and cyclones to deal with. The cheap Bissell are easily user serviceable. If people would just wash their dang filters.
Junk
It’s junk in my opinion and don’t know why Bissell would produce such garbage because after one buys it and uses it a while and realizes how cheap and crappy this vacuum is they likely won’t replace it with another…possibly better Bissell…they’ll likely buy a different brand. My partners parents had one of these they had bought for their sister because her Oreck died. They wanted something light and easy for her to push and it was intended for one large room only. It ended up getting used all over the house and while it did actually clean the carpet when the filters were clean…it had all of the issues mentioned above in the review and I completely agree on all of these issues. The filtration is not sealed either so dust would build up around the joints and other air leak areas as well.
Honestly, to buy this vacuum is a total waste of money that could be put towards something just a bit more expensive that will last far longer and not have these issues. I really think these were built with apartment dwellers in mind…a single person with a one bedroom apartment or efficiency who doesn’t have much need or room to store a larger vacuum. It does work…and would likely last longer for someone in that situation.
I had bought an earlier version at WalMart to have something for quick cleaning in between when the housekeeper came every two weeks. and was unimpressed with it and annoyed that it spewed dirt out from various places including the dirt bin if you bent it too much which opened the seal. It went back to Wal-Mart and I got a small Eureka instead which I like much better and kept until I moved to a house with no carpet and then gave it to a friend who needed a vacuum.
I would have to say that these Bissells are just the bottom of the totem pole when it comes to uprights and poor excuses for vacuums. I had gotten a power force bagged upright some years ago off someone’s trash and it needed a cord so I fixed that and it worked pretty good…not as good as a Hoover upright I had at the time but pretty good. It may have had a worn brushroll making it not perform as good. I gave it to a friend so he would have a second vac to keep upstairs and he actually said he liked it and his other vac was a Sanitaire commercial upright.
Production of such junk by Bissell really makes me dislike the company…though I will say I have a Bissell spin wave electric spray mop which I do like and do find to be pretty good quality.
It’s all just part of the unfortunate disposable vacuum world.
Jon
