mark40511
My little green is about 10 years old. Maybe even more than that...It works PERFECTLY except for one thing... I think the two O RINGS are disintegrating. What happens is the cleaner head is EXTREMELY difficult to get on/off. I have to use all my strength.If I mess with the O rings and try to get them right... the cleaner head goes on super easy on/off and stops leaking...but the motion when taking it back off/putting back on screws up the position of the O rings AGAIN.. When spraying, it leaks dripping at the point it connects..so you have this drip of water coming out as it's spraying unless I fiddle with the O rings each time....Does anyone have a clue which size O rings to get. Bissell was of NO help...Nor the local vacuum shop..
