I volunteer at a small sandwich restaurant every Tuesday and Friday. Over there is a Bissell Lift-Off Floors & More Pet 2-in-1 stick/hand vac.
One of my jobs over there is to vacuum the hallway. Overall, the performance of this vacuum is disappointing. It sometimes takes a few passes to pick up the lightest, smallest particles. I can only use it for about 10 minutes before the battery starts dying off.
Once I'm done, I plug the vacuum into the charger. Then a couple hours later, sometimes one of the restaurant employees will go to use it. And whenever she does, the battery dies off.
This vacuums looks and feels like a toy. It gets up some surface dirt, but the battery life stinks and it takes all day to charge. It must be plugged in 24/7 when not in use.
In addition, this vacuum has a detachable hand vac. Detaching and reattaching the hand vac takes a bit of strength. You have to hold down the release button and give it a forceful tug to detach, and to reattach, you have to line it up and give it a forceful push. Once detached, the hand vac has a trigger that must be pressed in order to run. You have to detach the hand vac every time you want to empty the dust bin.
And speaking of the dust bin, it fills up and clogs very easily. And when it overfills, the air passageway from the floor nozzle to the hand vac gets plugged up. I have to reach into the floor nozzle and pull gunk out by hand. I have to go through this almost every time I use this vacuum.
Also, like most cheap vacuums, the filter clogs quickly as well.
However, there are two aspects of the vacuum that I love: the swivel head and the folding handle. The swivel head is very nice for getting into tight spots, and the handle bends forward to allow for cleaning under chairs and furniture without straining my back.
Overall, in my mind, this vacuum is not worth $70. Has anybody ever used one? If so, how did it work out for you?
