bearings in bulk purchase?
rivstg1
colorado springs
I seem recall someone in the past posted about buying the bearings for older Kirbys ( I"m sure they were used in other vacuums as well) that were in 'bulk' ie.. 5-10 of them for way cheaper than purchasing individuals. Can anyone help me with this?
I would sure like to know this also, providing they are Kirby parts rather than chinesium skateboard bearings.
I have five machines that will need these later on when they are restored.
I just went over to my local bearing shop and bought a couple of 87008 (same as ND 8008) bearings for my Kirby 1C and 2C.
I've also bought a 1 lb. container of Lubriko grease for repacking bearings.
They can also cross reference bearings for you as well.
I don't see why oem Kirby bearings are needed. You could just buy from a reputable bearing manufacturer (which no doubt is what Kirby does). Whatever bearing you need, just measure it and use McMaster to find the 'trade number' - like 608ZZ for example. That's a metric bearing, and the digits after the first 3 change sometimes, they indicate whether it's sealed, open, or shielded, or sometimes a combo of two. Then google or ebay your trade number and just pick one from a known brand like SKF or Timken or Koyo. For example, google "608 ball bearing."
I mean, I've been buying Chinesium 'skate board' bearings from thebigbearingstore.com, so far, so good. It isn't the 1980s anymore - when you bought Chinese brake rotors and had to have them turned on a lathe again to make them straight lol.
There is no such this as
"Kirby Bearings". I have made quite a few Kirby refurb videos where I clearly show Kirby has used bearings from literally everywhere. Japan, Malaysia, Taiwan, China, etc.
The front bearings are typically 6200 and the rear are typically 608 types. You can get a 10 pack from eBay (I typically use PGN brand, located in Florida) for $10 (or less) and they arrive in 2-3 days (standard shipping rates).
Bill
What you do, look up the number on the bearing. There should be a number on it. If not measure it. Then look this up and you’ll find many options for buying that bearing.
