New member trying to refurbish the bearings on a Hover 450 form the late 30s. Found an on line manual from 1957 that covers pretty much all models up to then, but does not get into disassembly details on the motors with bearings. Trying to remove the drive pulley from the shaft, it appears in the manual to be left hand threaded, but there is no good way I can see to lock the shaft while trying to unscrew it. I can't hold the impeller while turning the pulley since the impeller is not apparently locked to the shaft in any way, it is just friction fit with everything tightened down.
There is a small hole in the bottom that appears to have some slotted screw at the bottom when I put a small screwdriver down there. It does not move after using penetrating oil on it. was hoping this might be holding the pulley on though it does not appear in the parts diagrams.
Next step seem to be a heating up the pulley with a torch and seeing if that frees it up.
Thoughts?
Steve
Thoughts?
Steve
