oldsuck
Active member
I was hesitant to select the Small Appliance button to post this, but there was no button for gigantic belt-drive fans.
I just bought this 1950s Homart Cooler after years of searching for a good one. It came in the original box with parts, instruction manual, and even the original allen wrench for adjusting the pulleys or something. Had to have it.
I knew I should have oiled it before turning it on, but I’m an idiot.
It ran beautifully for about 30sec, then when I tried to stop and reverse it from intake to exhaust, it stopped turning altogether, in either direction.
I tried to give the blades a couple shoves to get it going, but it wouldn’t take off. I didn’t leave it on like this for more than a few seconds, but it still smelled like it was burning a little.
I’m not too concerned yet. It probably just got hot enough for a second to heat up 60yrs of old grease, oil, dust, and hair. I’m fairly confident that with proper lubrication, it will run like new.
My question is this- how important is it to take it apart and clean the old oil off the shaft & bearings first?
My first instinct is to do it, of course, but it ran so beautifully, before it didn’t. It had no shaking, wobbling, knocking, or ticking, which is incredibly lucky for one of these 60+yr old beasts.
I’m afraid if I break it all down & put it back together, something will be off-balance and I won’t be able to fix it, and it will wobble and tick.
Could I just flood it with WD40, spin it a bit, blow it out with a can of air, then lube it properly? Or something?
One other thing- Nobody seems to agree on if the shaft takes oil or grease.
I have the manual, and it seems to have come with a tube of proprietary Sears Roebuck "Dripless Lubricant".
That sounds like grease to me. Any thoughts?
Thank you for your time.
P.S. The two screws on the top of the shaft are where you add the lubricant. I heard the tube of Sears lube screwed right into the holes to squeeze it in.
