Any knowledge about russian vacuums?
That's right, I said this in the apartment which has 2-4 rooms easier to clean with a vacuum cleaner hose and nozzles. I have 2 vacuum cleaner "Saturn" (1971), did not want to)?
VAMPUR
I got the vacuum cleaner "Vampire" company AEG, as I understand it is the second model in the first power cord coming out of the end of the handle. Who knows the timing of release of models of vacuum cleaners?
Lewyts..
Were introduced just after WW2 46 or 47, model 40 was the first one, they copied Filter Queens cone filter and got sued, the model 44 was much the same except they changed the rug tool, the model 55 came out in 1952 and it had a disposable bag, they had to do this because of the lawsuit...that and pay Health Mor, the makers of the Filter Queen 353000.00 in 1951 Money!!!the Big Wheel canister came out in 55 and was made thru about 60 or 61.
Vampyr
Yes, I saw this advertisement. This is the second model of vacuum cleaner advertisement "Vampyr". And it was the advertising, the earlier of the first model, I have a vacuum cleaner is also in the collection. They differ in the design of the handle and switch.
Vacuum Cleaner "URAL" started producing in 1976. These vacuum cleaners have a capacity of 600 watts and working voltage of 220 volts. Vacuum cleaner nozzle fit into a stand that can be hung on the wall. The hose wraps around the vacuum cleaner. A vacuum cleaner dressed leatherette cover and a vacuum cleaner turned into an ottoman, you can sit on kotrom)
Vacuum Cleaner "Ural" is very common in Russia, was released from a huge number. As for the hand-held vacuum cleaners "URAL - PR-54", "Ural - PR-56", that they were produced from 1954 to 1956, but not very much and this is now they are rare.
This vacuum cleaner in carbolite case - "Ural-PR-56"​​, 1956 edition. Operates from 127 volts. Versatile enough - different nozzles, and has a strong enough suction power))).
I did some research and used Google Translator with a Russian vacuum cleaner site... So, in the Soviet Union the mass production of vacuum cleaners began in 1952. The first model received a symbolic name - "Pioneer". In the same year “Dnepr” appeared. It became an indispensable assistant in many families. The Dnepropetrovsk vacuum cleaner, looked very much like a Swedish Electrolux. But Soviet consumers did not know this. The same plant in Dnepropetrovsk produced several more brands of vacuum cleaners. Among them are “The Seagull”, “Whirlwind”, “Buran” and, of course, the most famous “Rocket” («Chayka», «Vikhr'», «Buran», «Raketa»).
All products were made by hand, only high-quality metal was used. Testing was conducted very carefully. It was believed that if the "Rocket" to throw from the 8th floor, it will still work. This legend or fact is hard to say, but the durability and reliability of these vacuum cleaners deserves admiration.
