I've been wanting an Ell Dee(Birtman) since I was about 10, so I got this one about two weeks ago and have put a tremendous amount of work into it.
The front bearing was totally stuck(but works great now), and the rear one was wrecked, so I took a bearing from a tin can style motor, cut out part of the bearing plate to act as a spacer, and jammed a piece of metal in the back of the housing to help hold it in place. It runs great now! The whole vac was repainted on top of the old wrinkled paint, with a near perfect match. Not a perfect job, but it is miles better than the corroded heap it was. The original Ell Dee badge was long gone, so I painted a Royal type badge to match the vac. One of the brush bearings was incredibly pitted and frozen, so modified that end of the roller to use an Elite roller brush bearing. Now I just need to finish up on the bag repair, and repaint the handle pole.
This thing definitely scared the crap out of some young kids back in the day lol, it had to be one of the most imposing vacuums I have ever seen.
How is the middle wheel assembly supposed to go together? If I tighten the bolts the wheels won't turn, if I leave them a little bit more loose then pushing the vac makes the wheels undo the bolts.
