aeoliandave
My most vintage of vacuums, the Green Goddess, has had a dead motor since I found her 25 years ago lanquishing forlorn in a junk store here in town for $5. She ran for about ten minutes until giving up the ghost in a cloud of smoke and sparks and siezing death rattle noises. :-(
I found a similar model Air-Way 'beater' vac for parts a few months back on my travels so it's time the Goddess returned renewed to the Land Of Reborn Vacuums.
To do the Goddess Gertrude justice will take a bit of finicky work.
The donor motor's cord, in excellent unfrayed condition, runs to the inline bakelite switch and to the also excellent 24 foot clothwrapped cord terminating in a steel-cased wall plug (original?) pictured.
But, the Goddess' motor cord runs a short length up the handle terminating in a molded rubber triangular plug that plugs into the Goddess' handle rotary ring switch. 24" of this cord is in fine shape and the last 10" to the motor has been spliced and repaired several times. The 24 foot power cord for the Goddess is a total loss - frayed patched & crumbling with a modern plug.
So, the donor motor cord must be surgically spliced to the Goddess molded plug cord in an unnoticable manner. There is a short covered channel in the fan chamber case where the handle attaches that captures and centers the cord - to run up the handle between the bag retaining rods to the ring switch - and this is where the splice must be located to hide the repair.
Having now determined this, for the rest of the evening I've been refurbishing the donor motor...greasing bearings, cleaning the commutator, extracting dust bunnies and steel wool polishing up the donor motor housing. They are identical motors & fans except for the Air-Way label. I have taken the liberty of exchanging the enamel-on-brass plates, as the Goddess is Canadian made.
The donor motor is now gleaming and running real nice. The horribly corroded and cracked donor fan chamber came with a clean unbroken directional printed dial bubble which has been installed in the Goddess' rust free suction can.
Tomorrow night, the cordectomy.
