vgwpg
Hello, I am currently working on a project. I got a good deal on a VacuMaid P-225 motor pod with a brand new motor. I did not realize how loud they are until the first time I turned it on, and I have to say, I almost jumped to the ceiling in shock. Even for me, who doesn't really mind a loud vacuum, it's way too loud. Since I had an older S1600 housing kicking around, I decided to put the motor and control board from the P-225 pod into the S1600 pod. However, it is still quite loud.
I was wondering if it would be okay to add foam into the motor housing to quiet the motor? Will the motor run too hot? A lot of newer units are heavily lined, so I figure it is okay, but I want to make sure. I also don't know if there's a certain type of foam that will work better than others.
Also, is there a foam that I could put around the motor cooling air exhaust to capture the carbon dust?
I've attached a couple of pictures below, in case it might help.
Thanks!
Thanks!
