durango159
I have feedback for Hoover for more Power nozzle canisters!
I want to see more power head bagged canisters. I want something that looks, cleans and sounds like a Hoover. A Duros is a not a True Hoover in my mind. The Anniversary Windtunnel is ok, but the suction unit has a very different tone from previous Hoover canisters. The hose on the Anniversary Windtunnel is terrible-- not very flexible and I actually find the hand grip uncomfortable for vacuuming with the power nozzle. The old style PowerMax/ Windtunnel hose was comfortable and on/off agitator button was perfectly positioned. Also the material was terrific-- lightweight, flexible and durable. The problem with that hose was the attachment lock-- it was never designed right. On a new PowerMax/ Windtunnel hose, it was very hard to slide the lock over to lock in wands and attachments. After a few years of use, the lock became worn and eventually it opens up on its own. In contrast the hand turn lock on Futura, Dimension 1000, Celebrity and Spirit hoses was phenomenal. Very easy to use, never had a problem with it locking and unlocking and holding the tools in place successfully without opening on its own.
There are people upset with Hoover because they don't have a canister vac with on/off switch for entire unit on handle, as used to be on several deluxe models of Windtunnel and PowerMax. There are people upset with Hoover because the attachment set is not what it used to be. The crevice tool on the S3670 Anniv. Windtunnel canister is quite short and not wide enough. The reason its not wide enough is because it makes that extra obnoxious hissing sound when using it. Compare noises of crevice tool in use with former Windtunnel canister and newer Windtunnel canister, it doesn't matter what suction level the new one is set to, that crevice tool sounds awful. The combo upholstery/ dusting tool is cheap. Yes Riccar has one but many of their machines come with several attachments. Go back to an upholstery nozzle similar in style and shape to the former version with rubber fingers. That shape was much easier to use on steps, sofas, etc. Try using the S3670 upholstery nozze on a sofa-- you'll hate it, the elongated design for that doesn't work. The dusting brush designed that elongated way isn't too bad! The bare floor brush is awkward and doesn't clean as good. First off save your costs and get rid of the 2 side wheels, they're useless. A bare floor brush should just be brush, no wheels. Secondly save costs again and shorten all the bristles so the head is closer to the floor making it lower profile and allowing suction to pickup heavier objects like small stones.
Headlight is a must-- but keep suction duct sealed-- do not have rubber spokes from headlight extending down into suction duct. It would be nice if Hoover incorporated a manual pedal operated height adjuster into their bagged canister power teams. Keep the suction duct extending around the belt, that's a must. Rubber coated wheels. Square off wheel axle ends on power nozzles. The wheels should turn but not the axles that's part of why all the Windutnnel PowerMax heads squeak so bad.
I've been vacuuming with Hoover canisters for over 20 years. My parents and I have owned and used extensively the Celebrity II Elite, Dimension 1000, TurboPower 5000, several PowerMax's, Windtunnel S3630, Windtunnel Plus S3639, Windtunnel Anniversary S3670. This is my feedback, I don't want to switch to another brand of canister vac.
