Hello,
As a Kirby newb, I have a question about the Tech Drive on a used G5. First off, the Tech Drive works. That's great news. I think the vacuum is very cool and will be a pleasure to use.
Since it is a used vac and because this is my first and only experience with a Kirby G series, I am really not sure if it's working optimally, however. Or if it's worn and will need some maintenance.
When I use the Tech Drive, it makes a highish pitched mechanical whirring when I push or pull it. Every time I changed direction, from push to pull or vice versa, there's a faint click as I change directions, and then the highish pitched mechanical whir as the vacuum moves. The whir disappears when the vacuum is not moving. The whir is not super loud, but definitely noticeable. It doesn't sound like anything is broken or like anything is grinding. Just a whir, like you'd imagine a robot's arm to sound as it moves.
There is no grinding at all, either on drive or neutral. The power assist is felt and appears to be working.
So my question is: is this the normal sound of a healthy Tech Drive? Also, does the transmission need regular maintenance and if so how would you go about maintaining it?
Thanks for your help!
