I used my Avalir Shampoo system for the first time this morning. I cleaned two rooms and got the feel of the system. It's different in several respects from older models. For me, the two biggest changes are the lift-out tray where the spent shampoo collects and the brush roll itself. I really welcome the lift-out tray. It's deep enough to collect an entire tank's worth of residue, and probably more. Detaching it from the unit itself is easy: It just lifts out, then balances itself so that no liquid spills from it. On older models, you had to detach the entire unit from the front - uncovered - and carefully thread through the house to the closest sink to empty. By just pulling up and removing the tray, the process is easier, with little risk of soiled water splashing about. The shape of the brush rows is different, and maybe another Kirby person can tell us what the advantage is to that. Also, the "rollers" that allow the brush to be attached to the unit are identical. I don't think it matters which way the brush is inserted.
My only reservation is the tube connecting the tank to the brush unit: it's in a fairly stiff rubber or plastic which makes it difficult to manipulate into position. I hope this feature is reconsidered by Kirby. Most definitely awkward, especially at first.
But the results were excellent: the carpet is clean and fresh, and dried in record time.
