adiostoreador
So a little while back I bought this new Carpet Shampooer from Ollie’s. My old one was finally on its last leg and so I figured time to invest in a new one. This model from what I can tell was a $170-$200 dollar system originally and it was the TOL model. It had decent reviews so I decided to see how much they were at Ollie’s and I about had to pinch myself, $100 dollars for it. I am not too sure if these are a refurb or a buyout of an old color they discontinued, I lean towards buyout as it came in an original Hoover box with all the expected kit and caboodle. Today I finally got to use it as I felt my carpets need it. I started with my living room and will slowly move through the house on my days off. I vacuumed the carpet in the living room with my Miele U1 AutoEco before I started to make sure they were as clean as can be and then I was off. The Hoover did excellent work on the carpets and they felt mostly dry to very slightly damp thanks to the forced heat. I was amazed with what it pulled out and it is SUPER easy to use. I especially like the fact it has a twin chamber design for the water/solution, have the dial set one way to wash the other way to rinse! I usually would just refill the tank on my old cleaner with water to do a rinse after washing so I found this nice to have as it kinda cuts out a step in the process. Plus I do like not having to mix the solution, just fill and go and its mixed as needed. Overall I think I got a good machine for the money and am fairly impressed with the results. Hope it last as long as the old cleaner did!
