Oreck HEPA Cordless Upright Bagged Vacuum Cleaner BK95520PC
niclonnic
Bonney Lake, WA
I got this vacuum for Christmas. It is a cordless, bagged upright from Oreck. That's right; I am now the owner of a BAGGED vacuum cleaner! I never thought I'd see the day when I actually own one.
The vacuum has a futuristic design and is very lightweight (even with the battery installed), which Oreck is known for. However, there are no attachments, so this is a floors-only machine. It features some brilliant LED headlights, which are the brightest I've ever seen on a modern vacuum. Compared to my old Bissell Pet Hair Eraser Lift-Off (which I don't have anymore), the lighting on the Oreck is a lot more even.
The vacuum is powered by a removable and rechargeable 20V max, 6Ah ONEPWR lithium ion battery, which takes about 3 hours to charge. Just a few minutes of vacuuming depleted 1 light out of 4.
Since it's a bagged vacuum, there's no messy dirt cup to deal with or filters to wash. The bags feature HEPA filtration and can hold up to 4 times more dirt than a typical bagless vacuum. In addition, they have a SaniSeal system which prevents the dirt from flying out of the bag while changing it. Hopefully, this will be better for my allergies. The vacuum came with 4 bags, one of which was pre-installed for convenience.
I tested it out, and it is pretty powerful for a cordless vacuum! It doesn't scatter debris on hard floors, and on carpets/rugs, the brush roll causes surface dirt to dance around. I was surprised at how good the agitation is. And when I touched the bag, I could hardly feel the dirt in there.
However, there are some cons with this vacuum. The lack of attachments means I can't get into crevices or corners, vacuum up a small spill or do stairs. The bags are consumable parts which could get expensive over time.
There is a squeegee on the bottom near the brush roll which prevents scattering, but it makes a loud scraping noise when I run the vacuum across my laminate floors. In addition, it causes the vacuum to skip/hop on rugs. But I suppose that's a minor inconvenience.
So far, I think it's a great cordless vacuum that performs just as well as a corded unit.
Oreck vacuums never had attachments, that's why most premium models came with a Oreck Buster for free, that you would use for above the floor cleaning (also could be sold separately).
What kind of filtration is that bag meant for? This is the first time I've ever seen a purple vac bag!
The vacuum looks like they took their Oreck Axis model and modified it slightly to be cordless. Looks like the bag shrunk to account for the balance between airflow and battery life.
I might have to try one someday when it's cheap, still hunting down a Magnesium.
Hoover sells their version for $299, which is tempting. I haven't seen any real real pictures of this model yet so this was fun to see! Thankfully this looks like any other Oreck they've been selling for the past few decades. The brush roll looks a little narrower than the corded ones, but I could be wrong. CC bags are huge and cheap. They've been for sale since 1997 so they're everywhere. Does the motor sound similar to Oreck's usual 4amp?
My XL Classic finally died last week after 17 years of pretty regular use. Your Oreck will definitely outlast the original battery, so it's just a matter of them offering replacements. Congrats!
Love mine
I’ve had mine for awhile and love it for what it is, it could replace a full-size vacuum I think.
Wouldn't the battery on the bottom front bump into things or make it hard to get under furniture?It would be interesting to try it-the vac shop here doesn't stock these machines.Like my Simplicity Freedom cordless.I have been having problems with the chargers-sometimes they work well-other times they burn out.Has happened a few times-voltage at my place normal.The chargers have been replaced under warranty.
@huskyvacs As I've stated in the OP, the purple bag is meant for HEPA filtration. The fact that the outer bag is smaller means that the filter bag doesn't fully fit in the compartment; it must be tucked in to a degree.
@bagintheback The motor on this Oreck does sound different than their typical 4-amp motor; it's quieter and sounds like a jet engine when being turned on.
@tolivac The battery MIGHT bump into objects, so I'll have to be careful when steering the vacuum under low furniture.
The advantage of the Sinplicity-Riccar models is the battery is on the back of the handle.It is in a slimmer case.It would be neat to try the Oreck,though.What is with the striking purple bags?
Very nice.
Looks very sharp! Now if they could only make a cordless Electrolux canister. The cord winder could be removed and a big battery pack placed in its butt.
I looked at the Hoover version. It seems to be about the same. Kind of odd seeing the Hoover logo on Oreck CC bags from the 90s.
About the bags...
Since I'm frequently being asked about the "striking" purple bags, I'll answer to everybody at once: They are high-quality HEPA filtration bags with 5 layers of filtration. Because of this high quality, the bags are pricey at about $30 for a pack of 6.
Oreck has color-coded their CC bags for identification: purple for HEPA (superior, 5-layer), green for anti-allergen (select, 2-layer) and blue for antimicrobial (standard, 1-layer).
Do they still make the bags with the charcoal?
Riccar offers nothing with charcoal in bags for their lightweight. I’d ditch my Supralite for this machine in a heartbeat if Oreck makes odor control bags that actually work.
Thanks niclonnic for clarifying the bags. I knew they were HEPA, just didn't know why they were purple. This must be a new thing Oreck has been doing, I have not heard of color-coded bags until today. They certainly are pretty!
luxlife
The bags with charcoal are no longer being made. But there is a silver lining: the purple HEPA bags have a layer of charcoal in them. I completely forgot to mention that while describing the bags.
So the purple color has a meaning-a color code system.Are the "purple" HEPA bags made for other Oreck upright vacuums-yes pricey but worth it.And Oreck bags are large like Kirby,Royal metal,Simplicity-Riccar bags-all hold a lot of debris!So price really isn't so much of an issue.Sevral quarts-to a couple gallons?I have some Oreck upright bags-for Magnesium-not purple but sort of tan color and have the charcoal in them.Do the purple bags fit the Magnesium-thats the Orecks I use.One with a pushbutton start at the back of the handle-bag housing-other has the "remote" start with the battery operated RF switch in the handle top.Like both machines.With these don't need a "broom" or stick vacuum.
Riccar/simplicity
If you get rid of the simplicity cordless I'd be Happy to take it off your hands. I know exactly your answer to that statement so no reason to say it.
Interesting and nice vacuum.Isn't this one the same as the Oreck version?The powerhed looks the same-bag looks the same,and the undermount battery.Sounds like it bumped into the chair you were vacuuming around.Looks like the main diffrenc is the name on the powerhead.I might like to get this or the Oreck version.
