40th Anniversary Oreck XL
The brushrolls are the exact same thing regardless which color of the bristles. Just be sure to order the one that has the metal pulley. The plastic pulleys are for the ones that uses a lifetime belt, they'll work but they're just more expensive so it's not really necessary to order one of those. The cord protectors help prevent the wires of the cord to come loose, that could be why your Ultra didn't work when you first got it. I'd recommend getting them. The seal you'd want to replace is the white one.
Thanks, Alex.
I should have made that more clear. The wires I was referring to are on the bottom. I'm guessing their original function was to prevent area rugs or some items from getting sucked into the brushroll. They're missing on all three of our machines.
And, for the felt seal, I've seen two different types listed for sale. Probably about the same circumference, but one seems wider than the other.
Is there maybe another similar seal between the fan housing and the motor?
A little update
For anyone who's interested in the continuing story of the Anniversary Orecks, it's kind of a big day in Junque land.
I finally got up the nerve to take the outer bags off and give them a bath. I went with hand washing, as usual. I was just too worried that the washing machine might damage them. It took every ounce of courage I could summon, just to pry the clips off the bottoms of the bags. I was sure I would break the clips. And, as we all know, finding the correct replacements would be next to impossible.
As I write this, they're both in the tub, in clean, cold water. I washed them in warm water and liquid Tide.
I was expecting a lot more dirt in the wash water! Maybe the Oreck inner bags do a pretty good job of containing even the fine dust. My Kirby bag, for example, made the water look like mud. I washed the two Oreck bags simultaneously, and there was hardly any dirt in the water!
While we have a few hours of daylight left, and the last 80 degree day we're going to have for the rest of the year, I'm going to set them outside on a drying rack.
When they're dry, I'd like to try to shave some of the fuzzy look off of them. I have one of those little battery powered clothes shavers, to remove pills and fuzzies. Has anyone ever tried that on a vacuum bag? I don't think it would do any harm. I'll try it in an inconspicuous area first.
Update to the update:
Before putting them outside on the drying rack, I put both bags in the washer, and gave them a low speed spin. It did get a good portion of the water out of them. Now, they won't need as much rack time as they would have if I had put them out there dripping.
Now, I'm off the give the bag docks and bottom clips a little wash in the sink.[this post was last edited: 10/28/2023-13:47]
Oh I see what you're talking about now. Honestly if you're careful of not sucking up the cord or rugs, you should be fine.
The seal you should replace is the bigger one like in the video. The smaller one should be fine still.
Lighted switch update:
I'm happy to report that the first of my anniversary editions once again has a lighted power switch!
Sometimes, (most of the time) it takes me a while to get up the nerve to attempt something. This was one of those times.
But, having had success with opening up the handle on the Ultra, and getting it running again by reattaching the wires, I finally got brave enough to open up the handle of the white one.
Just like on the Ultra, I was greeted by a wire that was disconnected from the switch. I had hoped it would be something that simple, but I refused to let myself get overly optimistic.
I hooked up the wire, put the handle back together, and plugged the cord in. To my delight, (deLIGHT) there was the power switch, glowing away!
I'm relieved that I didn't have to take the switch apart, or replace it. Knowing me, I would have just lived with the disappointment of the switch not lighting up.
They were pricey, but I bought a box of six Oreck brand HEPA bags; the purple ones.
Since I have no wall to wall, and just a few braided rugs, and I have several vacuums to choose from, it will take a very long time to fill a bag. So, they should last me a while.
We also have a very basic XL Classic that we bought new. I thought we got it in '02. But, I dragged it out the other day, and the date code says '04. So, it's actually a year newer than the 40th Anniversary models.
I'll probably take the "Classic" apart for a good "spa day" at some point, and hand wash its outer bag, which has never been done. At that point, maybe I'll treat that one to a purple bag too.
I hated to buy expensive bags, since I still have spare CC bags, in almost every flavor they made. Well...maybe not "almost every". But, a few different ones.
Some even came with the two recent acquisitions. But, I wanted to try the HEPA ones. Oh well!
I'm pretty pleased with the results of the fabric shaver on the outer bags, if anyone was wondering. They're not perfect, but it took a lot of that fuzzy look off of them.
That's great!
That's definitely the way to do it!
I never find them at the thrift stores. The last time I saw any vacuum bags, it was a couple of packages of vintage Hoover bags. Maybe for a bottom fill Convertible; which I don't currently own. I have two top fill Convertibles.
Plus, in the case of the Orecks, I wanted to try the HEPA bags.
I've watched videos too, where someone mentioned getting their genuine Oreck belts dirt cheap, because they buy them in bulk. I've never run across that deal either. I'm assuming they meant online somewhere, but I have yet to find it.
