whynotsmile
My Hoover vacuum cleaner keeps snapping belts. I've replaced a few, but literally as soon as I turn it on, with a few seconds it snaps.
I've had a look, and I think the issue is that the roller won't turn (it should turn fairly easily, right?). I've attached a couple of photos... One shows the bit that the end of the roller attaches to. Hopefully you can see that it has a few indentations.
The second photo shows the end of the roller which goes in to that bit. It has a strange looking bit of plastic which is sticking up. That seems to be catching on the indentations and jamming the roller.
I'm a bit suspicious of the bit of plastic, because it doesn't quite look like it's meant to be there... it's not nicely shaped or anything. It looks like someone could have been using a screwdriver to get the roller or and has kind of levered a blob of plastic up.
Any advice? I'm very tempted to plane the plastic bit off and see whether that helps! The other bit that the belt goes round (presumably connected to the engine) is going round fine.
