Hello,
I am trying to figure out some stuff...
After much thinking... it seems for an 'every day clean' the likes of Kirby or Rainbow will not be ideal.
Also given the $3000+ cost difference... Im gonna have to wait on the whole Rainbow/Kirby thing anyway.
Given this, I decided what would make most sense for me at the moment is to get a C3 Miele, and have that as my convenient go-to vacuum for every day use (quickly grab it out of storage, go over the floors quick, throw back in storage) - and then on the side when finances allow, I can have either a Rainbow or Kirby for that 'real clean' finish one a week/fortnight.
So, having decided to go with the Miele (never read anyone saying they don't actually clean properly)... I am trying to figure out which canister model to buy...
Looking at all the different models, it seems the model differences from $500-$1200 is just based on certain features and attachments. The wattage of the machines, some 1200w and some 2000w... they told me that it just means thats how much power it takes to run, nothing to do with the vacuum/airflow etc of the machine.
So in end they are all identical just come with different stuff and run 2 different Wattages.
The most expensive one (Green) is the Electro line... they told me if I want to use an electrobrush... that is the ONLY model that works with the brush. The rest of the vacuums are not. I asked can't I just buy the electrobrush head and add to the other models... answers No.
So if I want the electric turbo brush..... there is only that one model to buy.
If I don't care for it, then I got a whole arrange of models I can get and if one hasn't got what I need, I can either buy the more expensive unit, or just buy the head I need and add to the cheaper Vacuum.
They are all sealed units and all the same just different heads and filtration. Some use Active AirClean filters with charcoal to minimize odours, others use HEPA for smaller particle capture but not so much designed for odours like the Active Filter.
Uhm...
What exactly is the difference between the Active Air CLean Filter and the HEPA? Which one will clean 'better'?
I was told they clean the same, even on website both state 99.97% particle filtration... so I kinda dont get why HEPA is even needed then for allergies when both say 99.7%... ??
Other than that..
Do I need an electric brush, or is the Turbo brush good enough? - Only thing I found with turbo brush in thick hair carpet... as soon as the head is put on the floor, the brush stops spinning... the electric one on other hand would keep turning? Or is the electric one just to help you push the head along the carpet... not because it adds any cleaning benefit?
Uhm...
Other than that..
