wyaple
In searching around YouTube, I came across two videos that appear to depict an airflow and water lift measurement for the E2 2-Speed machines. These seem to be accurate and show the machine achieving:
77 CFM at the hose end (not the nozzle end) and
74" water lift at the canister base (not the hose end).
If these measurements are approximately correct, what does everybody think about this level of performance for a modern Rainbow costing thousands? And if these measurements are incorrect, what should they be?
Airflow Link:
Water Lift Link:
For comparison purposes, here's the same readings from my D4C SE PE:
Water lift from base = 60"
Airflow from hose end = 60 CFM
So for the newer E2 2-Speed, that's an improvement of:
74" - 60" = 14" (23%) better at the base and
77 CFM - 60 CFM = 17 CFM (28%) better at the hose end.
Quite a nice improvement from the switched reluctance motor!
BUT, is this enough performance when other machines (read: cheap plastic bagged vacs) can do much better at a tiny fraction of the price?
Bill
Airflow Link:
Water Lift Link:
Bill
