The Bissell Powerforce Helix at my local food bank was NASTY! So today, I decided to give it a good cleaning. First, I washed out some parts. These parts included the inner pleated filter, the outer circular filter, the pre-motor filter, the dirt container, the cyclone separator and the filter cup. As I was washing the parts, my sink water was BLACK. This shows just how filthy this vacuum was.
In addition, I wiped down the outside of the vacuum, as well as inside the upper tank, to make it look like new again. The base of the machine was coated in dust!
Also, the hose had dust and debris trapped inside of it. I removed the hose and shook it over a trash can to knock out that debris.
So when I come back to volunteer after spring break, this vacuum should have TONS of suction!
Do you wash the parts on your bagless vacuums on a regular basis? And does anybody wipe down their machines regularly? How about removing debris trapped inside hoses? This was probably the filthiest vacuum I've ever worked on.
