ElectroLux Sidekick compatibility
Thank you. Frankevacs are sort of a specialty of mine. I saw someone do the same conversion to a G-P minus the blue skins many years ago and it has been something I burned to do myself. It was a fun project and it ends up being a pleasure to use.
My Electrolux is currently a Frankenvac.
I combined a 1205 with SuperJ.
I luv the teal (?) color of the 1205 canister, but not the SuperJ's gold canister. And the SuperJ's powernozzle will stand upright by itself, while I have to lean the 1205's teal powernozzle against a wall or something or it will fall over.
So I use the SuperJ's chrome looking carpet powernozzle. And the Sidekick for smaller areas.
... a question ... my 1205 seems less powerful than the SuperJ. Are these 2 motors the same rating? Can I swap them?
The 1205 and Golden Jubilee used the same motor. The Super Jubilee, or Super J for short, used a different more powerful motor. I don't know if they are interchangeable.
That sounds right.
The Super J motors proved unreliable. I believe many overheated and had to be replaced. Someone with more Electrolux experience can chime in and correct me. They were redesigned for the Olympia and again for the Silverado. The Silverado is where they really got it right. Great power with fantastic reliability.
The Super J required a million-dollar retooling at the Connecticut plant. The tank body was different as well. I've never tried that swap you propose. The 1205 motor is actually the last iteration of the G model motor, with different brush holders and stronger than the original G motor. A fire at the Connecticut plant damaged the line where the Super J motor was made. So they outsourced the armature, and that's when they had motor problems. As usual, Electrolux handled every warranty issue, so it's doubtful there are many survivors with the troublesome factory motor.
I've worked on at least a dozen factory Super J motors and never had an issue. You raise an interesting query. There are aftermarket motors we discussed in VL that will fit in, like the Diamond Jubalee. Maybe one of those could fit in the 1205, or perhaps the Super J motor could fit in the 1205 with some minor modification....I dunno. I, too, like the color and style of the 1205. Very 'Jetson' looking vacuum. I agree that the 'gold' coloring of the Electrolux tanks of that period was very blah. But then I've met folks who love that color scheme, mainly because it reminds them of the vacs from their youth.
My ex had a later Aerus tank that had trouble. She took it to the dealer in Spokane, and they gave her a 'loaner' old Super J to use in the interim. Meanwhile, the dealer lost her vac, and she just kept the Super J. She says it's a better vac anyway. The hoses were always an issue with the vintage Electrolux tanks. Aerus was selling them for $150, but I don't know if they still are. That's a bitter pill to swallow, paying that for a hose and putting it on an old vacuum. Lots of old hoses on eBay, but most sellers think that if any air can pass through them, they're OK. The Asian-made hoses are trash: the chrome falls off, or they don't even fit accessories. As late as the early 2000s, they were OK to buy, and then it changed dramatically. Keep your wits about you when purchasing old hoses of any manufacture.
Kevin
Kevin
How about a replacement hose from Perfect or Clean Obsessed? Same canister connection as the Super J uses and they seem to pay attention to quality. I have a Perfect and aside from color and a power nozzle on off switch it is indistinguishable from an Electrolux hose.
I haven't bought a new hose in probably 12 years or so. When Asian aftermarket hoses started going downhill, you could tell by the price whether it was a good hose. Then the people selling aftermarket Asian hoses raised their prices so you couldn't tell the difference anymore. You just had to buy one and take a chance. So $150 @Aerus or take a chance......
Do you know where the Perfect and Clean Obsessed hoses are made? I would love to promote an Electrolux hose product if it's decent. I'll buy one to try out unless it comes from China.
*Update: I just looked at the Perfect hose. It "looks" the part. How does it adjust airflow at the head, or does it? For $69 on sale, I should try one.
Kevin
Kevin
Try closer to $275 for a gen-you-whine Aerus hose. The 12 footer for my Guardian Platinum cost me $400, and that was the lowest price I could find out here. The other dealer wanted something like $465. Highway robbery. I take my chances on the aftermarket.
Well, that shows you how long ago I was told the Aerus hose was $150. I'm done even considering that choice @$275.
The most significant caveat on the aftermarket hoses was the chroming/sizing. I've never seen an Electrolux OE hose chrome problem. Maybe if one left one in a pool of water, etc. I have three aftermarket hoses that won't fit my Sidekicks unless I remove some chrome or use boy butter. They go in the OE PNs, but way too tightly. I hate them and whatever standard specs they were made to.
I ordered the Perfect.....I'll let ya know what I think when I receive it.
Kevin
They were redesigned the motors right after SuperJ were introduced. Adding more iron to the armatures among other things. They increased the motor warranty to 5 years and added the fancy sticker to the top of the vacuum to indicate the change. There were later improvements to Olympia motors with fins added to the top for better cooling . Back in the day I was replacing as many as 5 armatures a day under warranty. I worked at one of the busiest Electrolux branches on Long Island at the time.
Olympia and early Silverado used the same motor. Later model Silverado were fitted with a DJ motor.
Kevin
Dealers ( stealers ) set their own prices and the ones where I live are greedy in the extreme. It may very well be that a dealer in the east sells the same hose for much less. In fact I use a dealer in Tennessee for my parts.
I really have no idea. I've had minimal contact with the Aerus dealer, some 60 miles away. Years ago, somehow, they found me and sent a salesman out here to "check my machine and bag supplies". I didn't mind at the time, but the salesman was Slick Willy! He immediately gave up on the vacuum pitch and started in about how my house smelled. I had an old dog that was nearly dead, raising my grandson, and yeah, there was odor. Slick as Santa Claus, he flew out to his car and brought in a Guardian air purifier. $2,000 later, I was staring at the machine on the floor.
To his credit, it did everything he claimed it would do. But the filter is crazy expensive, and the ultraviolet light is costly. For a while, that was only available at an Aerus dealer. And when I had to call them, they always sent that salesman back. It was a vicious cycle until the guy was hospitalized and died. About that time, the filters and light started to show up on the Net.
Kevin
It was, of course. It should have been more like $1,000 or less. It has N.A.S.A. filtration technology, and the Germans tested the cr*p out of it on mold & spores. Built like a tank...the fan part. Not especially easy to replace the ultraviolet light, but the filter is easy to replace. It would be a great unit to find used/cheap. I take it outside once a year and blow it out with a compressor.
Kevin
Kevin
From what Aerus and now former Tristar dealers tell me Aerus bread and butter are their air purifiers. They changed their corporate name to ActivePure after the name they gave their filtration technology.
Wouldn't surprise me a bit, as I can't be the only sucker out there. But when you have an overpriced item like that and make your customers think they have to keep coming back for proprietary parts, they will find aftermarket alternatives. Especially the way Aerus treats one on the phone here. The original ultraviolet bulb was made in Hungary, I believe, and then the aftermarket ones I found were made in Slovakia. I doubt if there's much difference between those two competing nations. The filters, on the other hand, well, things got weird. The first aftermarket filters said the same thing in print as the old Aerus filters did, but this last one was a blank slate. I can't really tell if I'm getting screwed there or not.
Kevin
Kevin
They are selling as many big industrial / commercial air filtration systems as fast as they can manufacture them. That is apparently where the real money is and it started during the Covid pandemic when the demand for air filtration systems in schools, hospitals and other public buildings went wild.
Makes sense. Well, I can't speak for the commercial units, but the Germans had 'test' rooms where they put spores and mold on the walls to test the machine I have, with results that were extraordinarily detailed. I can only imagine if Aerus holds to that on a commercial scale, they should be extraordinary units.
But if Aerus is involved, expect the cost to be higher than anyone else's equipment. My unit was bought about 6 months before COVID. I'm betting they're fighting copycating and copyright infringements.
Kevin
I have both the original, teal wrapped hoses (2x) that came with the 1205, and a replacement plastic hose that came with the SuperJ. So I've been using the replacement hose for my frankenmonster. Interestingly, the hose color is a kind of biege that matches that trim color of the 1205.
