Polishing Extravaganza, The Eclipse Cleaner
Beautiful Machine Bvac6
With the G.E. corp. logo, the Kenney patent tag,
and side air slots on the motor housing, I'm
guessing your Eclipse dates from 1915-1920?
If you ever get tired of it, I've got a nice place for it!
Frank
Does the label give an indication of the company who made it? Obviously, it's based on the Frantz Premier, which was Jim Kirby's first production model vacuum cleaner. In 1918, GE bought Frantz Premier. Frantz Premier then became Apex. Wondering if it was made by GE (the "new" Premier) or Frantz?
The label states Manufactured For Eclipse Machine Company in Sidney,Ohio. There is a key on the underside of it that when turned releases the nozzle. I assume its a hookup for attachments or something.
1915 "Princess" vacuum cleaner by the Suction System Cleaning Company of Sidney. Related?
No ads, photos or illustrations located.
    252 KB
Amazing work. I have a hard enough time keeping a shiny new Avalir 2 shiny much less shining up something to the luster we see that was as dull as it was when you started. Bravo for a great job.
If you want to polish a Kirby real well steel wool, mothers mag and aluminium polish and autosol aluminium polish. 0000 steel wool with the Autosol and polish, then 0000 with Mothers Mag And Auminium polish. That came from the Kirby Enthusiast. My little addition is the use microfiber, denim or leather to polish it a bit more with silver/aluminium dip.
VacLab and HooverLux both have good videos on how to polish Kirby. Keep in mind Kirby uses anodized aircraft aluminum so it might be a bit different than an antique cast aluminum vacuum.
There should be a final coat you can put on of a spray on wax or something that creates a protective finish to keep the metal from re-tarnishing so easily.
Try some silver dip on microfiber, denim or leather.
Eh Silverdip is for silver jewelry or silver dinner ware ( cutlery and utensils ). It makes me pucker to use it on aluminum. In any event the aluminum isn't tarnished it just gets dull easily and / or water spotted from my sweat ( ! ) and requires some upkeep.
